Oops! An error has occurred!
The following notes should help you.
An exception occurred while executing ‘SELECT count(DISTINCT s0_.id) AS sclr0 FROM s_articles_details s0_ INNER JOIN LEFT JOIN s_articles s2_ ON s0_.articleID = s2_.id WHERE s0_.kind = 1’: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘LEFT JOIN s_articles s2_ ON s0_.articleID = s2_.id WHERE s0_.kind = 1’ at line 1 in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 91
Stack trace:
#0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(702): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(PDOException), 'SELECT count(DI...', Array) #1 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection-\>executeQuery('SELECT count(DI...', Array, Array, NULL) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(286): Doctrine\ORM\Query\Exec\SingleSelectExecutor-\>execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(794): Doctrine\ORM\Query-\>\_doExecute() #4 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(598): Doctrine\ORM\AbstractQuery-\>execute(NULL, 3) #5 vendor/doctrine/orm/lib/Doctrine/ORM/Tools/Pagination/Paginator.php(143): Doctrine\ORM\AbstractQuery-\>getScalarResult() #6 Shopware/Components/MultiEdit/Resource/Product/Filter.php(170): Doctrine\ORM\Tools\Pagination\Paginator-\>count() #7 Shopware/Components/MultiEdit/Resource/Product/Filter.php(196): Shopware\Components\MultiEdit\Resource\Product\Filter-\>getPaginatedResult(Object(Doctrine\ORM\Query)) #8 Shopware/Components/MultiEdit/Resource/Product.php(111): Shopware\Components\MultiEdit\Resource\Product\Filter-\>filter(Array, 0, '25', Array) #9 Shopware/Controllers/Backend/ArticleList.php(364): Shopware\Components\MultiEdit\Resource\Product-\>filter(Array, 0, '25', Array) #10 Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ArticleList-\>filterAction() #11 Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('filterAction') #12 Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #13 Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #14 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #15 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #16 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #17 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #18 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #19 {main} Please help to solve the above SQL Errors
