Type: Symfony\Component\DependencyInjection\Exception\ParameterNotFoundException
Message: The parameter “shopware.db” has a dependency on a non-existent parameter “G”. Did you mean this: “shopware.model.autoGenerateProxyClasses”?
File: /var/www/vhosts/mein.shop/httpdocs/vendor/symfony/dependency-injection/ParameterBag/ParameterBag.php
Line: 102
Trace
#0 /var/www/vhosts/mein.shop/httpdocs/vendor/symfony/dependency-injection/ParameterBag/ParameterBag.php(234): Symfony\Component\DependencyInjection\ParameterBag\ParameterBag->get(‘G’)
#1 [internal function]: Symfony\Component\DependencyInjection\ParameterBag\ParameterBag->Symfony\Component\DependencyInjection\ParameterBag{closure}(Array)
#2 /var/www/vhosts/mein.shop/httpdocs/vendor/symfony/dependency-injection/ParameterBag/ParameterBag.php(244): preg_replace_callback(’/%%|%([^%\s]+)%…’, Object(Closure), ‘WQ!p%G%U4z0rG~O…’)
#3 /var/www/vhosts/mein.shop/httpdocs/vendor/symfony/dependency-injection/ParameterBag/ParameterBag.php(189): Symfony\Component\DependencyInjection\ParameterBag\ParameterBag->resolveString(‘WQ!p%G%U4z0rG~O…’, Array)
#4 /var/www/vhosts/mein.shop/httpdocs/vendor/symfony/dependency-injection/ParameterBag/ParameterBag.php(179): Symfony\Component\DependencyInjection\ParameterBag\ParameterBag->resolveValue(‘WQ!p%G%U4z0rG~O…’, Array)
#5 /var/www/vhosts/mein.shop/httpdocs/vendor/symfony/dependency-injection/ParameterBag/ParameterBag.php(149): Symfony\Component\DependencyInjection\ParameterBag\ParameterBag->resolveValue(Array)
#6 /var/www/vhosts/mein.shop/httpdocs/vendor/symfony/dependency-injection/Compiler/ResolveParameterPlaceHoldersPass.php(59): Symfony\Component\DependencyInjection\ParameterBag\ParameterBag->resolve()
#7 /var/www/vhosts/mein.shop/httpdocs/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\DependencyInjection\Compiler\ResolveParameterPlaceHoldersPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#8 /var/www/vhosts/mein.shop/httpdocs/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#9 /var/www/vhosts/mein.shop/httpdocs/engine/Shopware/Kernel.php(552): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#10 /var/www/vhosts/mein.shop/httpdocs/engine/Shopware/Kernel.php(240): Shopware\Kernel->initializeContainer()
#11 /var/www/vhosts/mein.shop/httpdocs/recovery/install/src/ContainerProvider.php(117): Shopware\Kernel->boot()
#12 /var/www/vhosts/mein.shop/httpdocs/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#13 /var/www/vhosts/mein.shop/httpdocs/recovery/install/src/ContainerProvider.php(126): Pimple\Container->offsetGet(‘shopware.contai…’)
#14 /var/www/vhosts/mein.shop/httpdocs/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#15 /var/www/vhosts/mein.shop/httpdocs/recovery/install/src/ContainerProvider.php(139): Pimple\Container->offsetGet(‘shopware.theme_…’)
#16 /var/www/vhosts/mein.shop/httpdocs/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#17 /var/www/vhosts/mein.shop/httpdocs/recovery/install/src/app.php(496): Pimple\Container->offsetGet(‘theme.service’)
#18 [internal function]: {closure}()
#19 /var/www/vhosts/mein.shop/httpdocs/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#20 /var/www/vhosts/mein.shop/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#21 /var/www/vhosts/mein.shop/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#22 /var/www/vhosts/mein.shop/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#23 /var/www/vhosts/mein.shop/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#24 /var/www/vhosts/mein.shop/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#25 /var/www/vhosts/mein.shop/httpdocs/recovery/install/index.php(75): Slim\Slim->run()
#26 {main}
