Hello everyone,
How’s it possible to change the position of the filters in the sidebar? I created some properties for my products like “Size”, “Material” and “Style” and they are displayed in the order like:
1 - Style
2 - Size
3 - Material
So I would like to move the size to the first place and the style to the second. I tried checking the file action-filter-facets.tpl but not sure if I can modify the order there.
Any tip would be great, thanks in advance.
Daniel.
Can you just pull the properites in backend into the right order?
@NextMike schrieb:
¿Puedes volver a colocar los derechos en el orden correcto?
Thanks for helping, but as I am new in shopware I don’t know how to do that in the backend, could you please point me where I can do it?
Thanks for the answer, I was actually doing it that way, but I was a little confuse because looks like you have to change the order for each set right? and the people from the shopware store I am working with, have more than 100 sets
, anyways, had to do it one by one.
Thanks!!!
