Shopware update schlägt weiterhin fehl auf 6.7.7.1 unter ionos
weiterhin schlägt das update fehl laut protokoll mangels memory laut ionos hätte der server genug
Protokoll
Run Update preparations
pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
pre-pool-create: Symfony\Flex\Flex->truncatePackages
Updating dependencies
Dependency resolution completed in 0.011 seconds
Analyzed 1297 packages to resolve dependencies
Analyzed 18984 rules to resolve dependencies
Lock file operations: 4 installs, 110 updates, 2 removals
Installs: symfony/polyfill-php85:v1.33.0, paragonie/constant_time_encoding:v3.1.3, phpseclib/phpseclib:3.0.49, thecodingmachine/safe:v3.3.0
Updates: symfony/runtime:v7.4.1, symfony/flex:v2.10.0, symfony/polyfill-php84:v1.33.0, shopware/core:v6.7.7.1, symfony/deprecation-contracts:v3.6.0, symfony/yaml:v7.4.1, symfony/finder:v7.4.5, twig/twig:v3.23.0, symfony/translation-contracts:v3.6.1, symfony/string:v7.4.4, twig/string-extra:v3.23.0, symfony/intl:v7.4.4, twig/intl-extra:v3.23.0, symfony/var-exporter:v7.4.0, symfony/polyfill-php83:v1.33.0, symfony/validator:v7.4.5, symfony/http-foundation:v7.4.5, symfony/event-dispatcher-contracts:v3.6.0, symfony/event-dispatcher:v7.4.4, symfony/var-dumper:v7.4.4, symfony/error-handler:v7.4.4, symfony/http-kernel:v7.4.5, symfony/twig-bridge:v7.4.5, symfony/service-contracts:v3.6.1, symfony/dependency-injection:v7.4.5, symfony/filesystem:v7.4.0, symfony/config:v7.4.4, symfony/twig-bundle:v7.4.4, symfony/translation:v7.4.4, symfony/stopwatch:v7.4.0, symfony/serializer:v7.4.5, symfony/password-hasher:v7.4.4, symfony/security-core:v7.4.4, symfony/clock:v7.4.0, symfony/scheduler:v7.4.4, symfony/routing:v7.4.4, symfony/options-resolver:v7.4.0, symfony/rate-limiter:v7.4.5, symfony/psr-http-message-bridge:v7.4.4, laminas/laminas-code:4.17.0, friendsofphp/proxy-manager-lts:v1.0.19, symfony/proxy-manager-bridge:v6.4.28, symfony/type-info:v7.4.4, symfony/property-info:v7.4.5, symfony/property-access:v7.4.4, symfony/process:v7.4.5, monolog/monolog:3.10.0, symfony/monolog-bridge:v7.4.4, symfony/monolog-bundle:v3.11.1, symfony/mime:v7.4.5, symfony/messenger:v7.4.4, symfony/mailer:v7.4.4, symfony/lock:v7.4.5, symfony/http-client:v7.4.5, symfony/cache-contracts:v3.6.0, symfony/cache:v7.4.5, symfony/framework-bundle:v7.4.5, symfony/dotenv:v7.4.0, doctrine/deprecations:1.1.6, doctrine/dbal:4.3.5, symfony/doctrine-messenger:v7.4.5, symfony/debug-bundle:v7.4.0, symfony/console:v7.4.4, symfony/asset:v7.4.4, squirrelphp/twig-php-syntax:v1.13, shopware/conflicts:0.6.0, setasign/fpdi:v2.6.4, brick/math:0.14.7, ramsey/uuid:4.9.2, lcobucci/jwt:5.6.0, league/uri-interfaces:7.8.0, league/uri:7.8.0, league/oauth2-server:9.3.0, league/flysystem:3.31.0, league/flysystem-local:3.31.0, league/flysystem-memory:3.31.0, smalot/pdfparser:v2.12.3, phpstan/phpdoc-parser:2.3.2, jms/metadata:2.9.0, jms/serializer:3.32.6, goetas-webservices/xsd2php-runtime:0.2.18, horstoeko/zugferd:v1.0.120, guzzlehttp/psr7:2.8.0, guzzlehttp/promises:2.3.0, guzzlehttp/guzzle:7.10.0, ezyang/htmlpurifier:v4.19.0, dragonmantank/cron-expression:v3.6.0, sabberworm/php-css-parser:v9.1.0, dompdf/php-svg-lib:1.0.2, dompdf/php-font-lib:1.0.2, masterminds/html5:2.10.0, doctrine/inflector:2.1.0, composer/semver:3.4.4, composer/composer:2.9.5, composer/class-map-generator:1.7.1, cocur/slugify:v4.7.1, react/promise:v3.3.0, marc-mabe/php-enum:v4.7.2, justinrainbow/json-schema:6.6.4, composer/ca-bundle:1.5.10, ezimuel/guzzlestreams:4.1.0, ezimuel/ringphp:1.4.0, pentatrion/vite-bundle:v8.2.3, shopware/administration:v6.7.7.1, shyim/opensearch-php-dsl:1.1.3, async-aws/core:1.28.0, shopware/elasticsearch:v6.7.7.1, meyfa/php-svg:v0.16.1, shopware/storefront:v6.7.7.1, shopware/paypal-sdk:v1.6.2
Removals: webmozart/assert, tecnickcom/tcpdf
  • Removing tecnickcom/tcpdf (6.10.0)
  • Removing webmozart/assert (1.11.0)
  • Upgrading async-aws/core (1.26.0 => 1.28.0)
  • Upgrading brick/math (0.13.1 => 0.14.7)
  • Upgrading cocur/slugify (v4.6.0 => v4.7.1)
  • Upgrading composer/ca-bundle (1.5.7 => 1.5.10)
  • Upgrading composer/class-map-generator (1.6.1 => 1.7.1)
  • Upgrading composer/composer (2.8.10 => 2.9.5)
  • Upgrading composer/semver (3.4.3 => 3.4.4)
  • Upgrading doctrine/dbal (4.2.5 => 4.3.5)
  • Upgrading doctrine/deprecations (1.1.5 => 1.1.6)
  • Upgrading doctrine/inflector (2.0.10 => 2.1.0)
  • Upgrading dompdf/php-font-lib (1.0.1 => 1.0.2)
  • Upgrading dompdf/php-svg-lib (1.0.0 => 1.0.2)
  • Upgrading dragonmantank/cron-expression (v3.4.0 => v3.6.0)
  • Upgrading ezimuel/guzzlestreams (3.1.0 => 4.1.0)
  • Upgrading ezimuel/ringphp (1.3.0 => 1.4.0)
  • Upgrading ezyang/htmlpurifier (v4.18.0 => v4.19.0)
  • Upgrading friendsofphp/proxy-manager-lts (v1.0.18 => v1.0.19)
  • Upgrading goetas-webservices/xsd2php-runtime (v0.2.17 => 0.2.18)
  • Upgrading guzzlehttp/guzzle (7.9.3 => 7.10.0)
  • Upgrading guzzlehttp/promises (2.2.0 => 2.3.0)
  • Upgrading guzzlehttp/psr7 (2.7.1 => 2.8.0)
  • Upgrading horstoeko/zugferd (v1.0.115 => v1.0.120)
  • Upgrading jms/metadata (2.8.0 => 2.9.0)
  • Upgrading jms/serializer (3.32.5 => 3.32.6)
  • Upgrading justinrainbow/json-schema (6.4.2 => 6.6.4)
  • Upgrading laminas/laminas-code (4.16.0 => 4.17.0)
  • Upgrading lcobucci/jwt (5.5.0 => 5.6.0)
  • Upgrading league/flysystem (3.30.0 => 3.31.0)
  • Upgrading league/flysystem-local (3.30.0 => 3.31.0)
  • Upgrading league/flysystem-memory (3.29.0 => 3.31.0)
  • Upgrading league/oauth2-server (9.2.0 => 9.3.0)
  • Upgrading league/uri (7.5.1 => 7.8.0)
  • Upgrading league/uri-interfaces (7.5.0 => 7.8.0)
  • Upgrading marc-mabe/php-enum (v4.7.1 => v4.7.2)
  • Upgrading masterminds/html5 (2.9.0 => 2.10.0)
  • Upgrading meyfa/php-svg (v0.14.7 => v0.16.1)
  • Upgrading monolog/monolog (3.9.0 => 3.10.0)
  • Locking paragonie/constant_time_encoding (v3.1.3)
  • Upgrading pentatrion/vite-bundle (v7.1.0 => v8.2.3)
  • Locking phpseclib/phpseclib (3.0.49)
  • Upgrading phpstan/phpdoc-parser (2.2.0 => 2.3.2)
  • Upgrading ramsey/uuid (4.9.0 => 4.9.2)
  • Upgrading react/promise (v3.2.0 => v3.3.0)
  • Upgrading sabberworm/php-css-parser (v8.9.0 => v9.1.0)
  • Upgrading setasign/fpdi (v2.6.3 => v2.6.4)
  • Upgrading shopware/administration (v6.7.0.1 => v6.7.7.1)
  • Upgrading shopware/conflicts (0.5.0 => 0.6.0)
  • Upgrading shopware/core (v6.7.0.1 => v6.7.7.1)
  • Upgrading shopware/elasticsearch (v6.7.0.1 => v6.7.7.1)
  • Upgrading shopware/paypal-sdk (v1.2.3 => v1.6.2)
  • Upgrading shopware/storefront (v6.7.0.1 => v6.7.7.1)
  • Upgrading shyim/opensearch-php-dsl (1.1.2 => 1.1.3)
  • Upgrading smalot/pdfparser (v2.12.0 => v2.12.3)
  • Upgrading squirrelphp/twig-php-syntax (v1.11 => v1.13)
  • Upgrading symfony/asset (v7.2.0 => v7.4.4)
  • Upgrading symfony/cache (v7.2.8 => v7.4.5)
  • Upgrading symfony/cache-contracts (v3.5.1 => v3.6.0)
  • Upgrading symfony/clock (v7.2.0 => v7.4.0)
  • Upgrading symfony/config (v7.2.7 => v7.4.4)
  • Upgrading symfony/console (v7.2.8 => v7.4.4)
  • Upgrading symfony/debug-bundle (v7.2.0 => v7.4.0)
  • Upgrading symfony/dependency-injection (v7.2.8 => v7.4.5)
  • Upgrading symfony/deprecation-contracts (v3.5.1 => v3.6.0)
  • Upgrading symfony/doctrine-messenger (v7.2.5 => v7.4.5)
  • Upgrading symfony/dotenv (v7.2.0 => v7.4.0)
  • Upgrading symfony/error-handler (v7.2.8 => v7.4.4)
  • Upgrading symfony/event-dispatcher (v7.2.0 => v7.4.4)
  • Upgrading symfony/event-dispatcher-contracts (v3.5.1 => v3.6.0)
  • Upgrading symfony/filesystem (v7.2.0 => v7.4.0)
  • Upgrading symfony/finder (v7.2.2 => v7.4.5)
  • Upgrading symfony/flex (v2.8.1 => v2.10.0)
  • Upgrading symfony/framework-bundle (v7.2.8 => v7.4.5)
  • Upgrading symfony/http-client (v7.2.8 => v7.4.5)
  • Upgrading symfony/http-foundation (v7.2.8 => v7.4.5)
  • Upgrading symfony/http-kernel (v7.2.8 => v7.4.5)
  • Upgrading symfony/intl (v7.2.8 => v7.4.4)
  • Upgrading symfony/lock (v7.2.6 => v7.4.5)
  • Upgrading symfony/mailer (v7.2.8 => v7.4.4)
  • Upgrading symfony/messenger (v7.2.8 => v7.4.4)
  • Upgrading symfony/mime (v7.2.6 => v7.4.5)
  • Upgrading symfony/monolog-bridge (v7.2.0 => v7.4.4)
  • Upgrading symfony/monolog-bundle (v3.10.0 => v3.11.1)
  • Upgrading symfony/options-resolver (v7.2.0 => v7.4.0)
  • Upgrading symfony/password-hasher (v7.3.0 => v7.4.4)
  • Upgrading symfony/polyfill-php83 (v1.32.0 => v1.33.0)
  • Upgrading symfony/polyfill-php84 (v1.32.0 => v1.33.0)
  • Locking symfony/polyfill-php85 (v1.33.0)
  • Upgrading symfony/process (v7.2.5 => v7.4.5)
  • Upgrading symfony/property-access (v7.2.8 => v7.4.4)
  • Upgrading symfony/property-info (v7.2.8 => v7.4.5)
  • Upgrading symfony/proxy-manager-bridge (v6.4.13 => v6.4.28)
  • Upgrading symfony/psr-http-message-bridge (v7.2.0 => v7.4.4)
  • Upgrading symfony/rate-limiter (v7.2.0 => v7.4.5)
  • Upgrading symfony/routing (v7.2.3 => v7.4.4)
  • Upgrading symfony/runtime (v7.2.8 => v7.4.1)
  • Upgrading symfony/scheduler (v7.2.3 => v7.4.4)
  • Upgrading symfony/security-core (v7.2.8 => v7.4.4)
  • Upgrading symfony/serializer (v7.2.8 => v7.4.5)
  • Upgrading symfony/service-contracts (v3.5.1 => v3.6.1)
  • Upgrading symfony/stopwatch (v7.2.4 => v7.4.0)
  • Upgrading symfony/string (v7.2.6 => v7.4.4)
  • Upgrading symfony/translation (v7.2.8 => v7.4.4)
  • Upgrading symfony/translation-contracts (v3.5.1 => v3.6.1)
  • Upgrading symfony/twig-bridge (v7.2.7 => v7.4.5)
  • Upgrading symfony/twig-bundle (v7.2.8 => v7.4.4)
  • Upgrading symfony/type-info (v7.3.1 => v7.4.4)
  • Upgrading symfony/validator (v7.2.8 => v7.4.5)
  • Upgrading symfony/var-dumper (v7.3.1 => v7.4.4)
  • Upgrading symfony/var-exporter (v7.2.7 => v7.4.0)
  • Upgrading symfony/yaml (v7.2.8 => v7.4.1)
  • Locking thecodingmachine/safe (v3.3.0)
  • Upgrading twig/intl-extra (v3.21.0 => v3.23.0)
  • Upgrading twig/string-extra (v3.21.0 => v3.23.0)
  • Upgrading twig/twig (v3.20.0 => v3.23.0)
    Writing lock file
    Installing dependencies from lock file (including require-dev)
pre-operations-exec: Symfony\Flex\Flex->recordOperations
Package operations: 4 installs, 110 updates, 2 removals
Updates: symfony/runtime:v7.4.1, symfony/flex:v2.10.0, symfony/process:v7.4.5, symfony/polyfill-php84:v1.33.0, shopware/core:v6.7.7.1, symfony/deprecation-contracts:v3.6.0, symfony/yaml:v7.4.1, symfony/finder:v7.4.5, twig/twig:v3.23.0, symfony/translation-contracts:v3.6.1, symfony/string:v7.4.4, twig/string-extra:v3.23.0, symfony/intl:v7.4.4, twig/intl-extra:v3.23.0, symfony/var-exporter:v7.4.0, symfony/polyfill-php83:v1.33.0, symfony/validator:v7.4.5, symfony/twig-bridge:v7.4.5, symfony/http-foundation:v7.4.5, symfony/event-dispatcher-contracts:v3.6.0, symfony/event-dispatcher:v7.4.4, symfony/var-dumper:v7.4.4, symfony/error-handler:v7.4.4, symfony/http-kernel:v7.4.5, symfony/service-contracts:v3.6.1, symfony/dependency-injection:v7.4.5, symfony/filesystem:v7.4.0, symfony/config:v7.4.4, symfony/twig-bundle:v7.4.4, symfony/translation:v7.4.4, symfony/stopwatch:v7.4.0, symfony/serializer:v7.4.5, symfony/password-hasher:v7.4.4, symfony/security-core:v7.4.4, symfony/clock:v7.4.0, symfony/scheduler:v7.4.4, symfony/routing:v7.4.4, symfony/options-resolver:v7.4.0, symfony/rate-limiter:v7.4.5, symfony/psr-http-message-bridge:v7.4.4, laminas/laminas-code:4.17.0, friendsofphp/proxy-manager-lts:v1.0.19, symfony/proxy-manager-bridge:v6.4.28, symfony/type-info:v7.4.4, symfony/property-info:v7.4.5, symfony/property-access:v7.4.4, monolog/monolog:3.10.0, symfony/monolog-bridge:v7.4.4, symfony/monolog-bundle:v3.11.1, symfony/mime:v7.4.5, symfony/messenger:v7.4.4, symfony/mailer:v7.4.4, symfony/lock:v7.4.5, symfony/http-client:v7.4.5, symfony/cache-contracts:v3.6.0, symfony/cache:v7.4.5, symfony/framework-bundle:v7.4.5, symfony/dotenv:v7.4.0, doctrine/deprecations:1.1.6, doctrine/dbal:4.3.5, symfony/doctrine-messenger:v7.4.5, symfony/debug-bundle:v7.4.0, symfony/console:v7.4.4, symfony/asset:v7.4.4, squirrelphp/twig-php-syntax:v1.13, shopware/conflicts:0.6.0, setasign/fpdi:v2.6.4, brick/math:0.14.7, ramsey/uuid:4.9.2, league/uri-interfaces:7.8.0, league/uri:7.8.0, lcobucci/jwt:5.6.0, league/oauth2-server:9.3.0, league/flysystem:3.31.0, league/flysystem-local:3.31.0, league/flysystem-memory:3.31.0, smalot/pdfparser:v2.12.3, phpstan/phpdoc-parser:2.3.2, jms/metadata:2.9.0, jms/serializer:3.32.6, goetas-webservices/xsd2php-runtime:0.2.18, horstoeko/zugferd:v1.0.120, guzzlehttp/psr7:2.8.0, guzzlehttp/promises:2.3.0, guzzlehttp/guzzle:7.10.0, ezyang/htmlpurifier:v4.19.0, dragonmantank/cron-expression:v3.6.0, masterminds/html5:2.10.0, sabberworm/php-css-parser:v9.1.0, dompdf/php-svg-lib:1.0.2, dompdf/php-font-lib:1.0.2, doctrine/inflector:2.1.0, composer/semver:3.4.4, composer/composer:2.9.5, composer/class-map-generator:1.7.1, cocur/slugify:v4.7.1, react/promise:v3.3.0, marc-mabe/php-enum:v4.7.2, justinrainbow/json-schema:6.6.4, composer/ca-bundle:1.5.10, ezimuel/guzzlestreams:4.1.0, ezimuel/ringphp:1.4.0, pentatrion/vite-bundle:v8.2.3, shopware/administration:v6.7.7.1, shyim/opensearch-php-dsl:1.1.3, async-aws/core:1.28.0, shopware/elasticsearch:v6.7.7.1, meyfa/php-svg:v0.16.1, shopware/storefront:v6.7.7.1, shopware/paypal-sdk:v1.6.2
  • Downloading symfony/runtime (v7.4.1)
  • Downloading symfony/flex (v2.10.0)
  • Downloading symfony/process (v7.4.5)
  • Downloading symfony/polyfill-php84 (v1.33.0)
  • Downloading shopware/core (v6.7.7.1)
  • Downloading symfony/deprecation-contracts (v3.6.0)
  • Downloading symfony/yaml (v7.4.1)
  • Downloading symfony/finder (v7.4.5)
  • Downloading twig/twig (v3.23.0)
  • Downloading symfony/translation-contracts (v3.6.1)
  • Downloading symfony/string (v7.4.4)
  • Downloading twig/string-extra (v3.23.0)
  • Downloading symfony/intl (v7.4.4)
  • Downloading twig/intl-extra (v3.23.0)
  • Downloading symfony/var-exporter (v7.4.0)
  • Downloading symfony/polyfill-php83 (v1.33.0)
  • Downloading symfony/validator (v7.4.5)
  • Downloading symfony/twig-bridge (v7.4.5)
  • Downloading symfony/http-foundation (v7.4.5)
  • Downloading symfony/event-dispatcher-contracts (v3.6.0)
  • Downloading symfony/event-dispatcher (v7.4.4)
  • Downloading symfony/var-dumper (v7.4.4)
  • Downloading symfony/polyfill-php85 (v1.33.0)
  • Downloading symfony/error-handler (v7.4.4)
  • Downloading symfony/http-kernel (v7.4.5)
  • Downloading symfony/service-contracts (v3.6.1)
  • Downloading symfony/dependency-injection (v7.4.5)
  • Downloading symfony/filesystem (v7.4.0)
  • Downloading symfony/config (v7.4.4)
  • Downloading symfony/twig-bundle (v7.4.4)
  • Downloading symfony/translation (v7.4.4)
  • Downloading symfony/stopwatch (v7.4.0)
  • Downloading symfony/serializer (v7.4.5)
  • Downloading symfony/password-hasher (v7.4.4)
  • Downloading symfony/security-core (v7.4.4)
  • Downloading symfony/clock (v7.4.0)
  • Downloading symfony/scheduler (v7.4.4)
  • Downloading symfony/routing (v7.4.4)
  • Downloading symfony/options-resolver (v7.4.0)
  • Downloading symfony/rate-limiter (v7.4.5)
  • Downloading symfony/psr-http-message-bridge (v7.4.4)
  • Downloading laminas/laminas-code (4.17.0)
  • Downloading friendsofphp/proxy-manager-lts (v1.0.19)
  • Downloading symfony/proxy-manager-bridge (v6.4.28)
  • Downloading symfony/type-info (v7.4.4)
  • Downloading symfony/property-info (v7.4.5)
  • Downloading symfony/property-access (v7.4.4)
  • Downloading monolog/monolog (3.10.0)
  • Downloading symfony/monolog-bridge (v7.4.4)
  • Downloading symfony/monolog-bundle (v3.11.1)
  • Downloading symfony/mime (v7.4.5)
  • Downloading symfony/messenger (v7.4.4)
  • Downloading symfony/mailer (v7.4.4)
  • Downloading symfony/lock (v7.4.5)
  • Downloading symfony/http-client (v7.4.5)
  • Downloading symfony/cache-contracts (v3.6.0)
  • Downloading symfony/cache (v7.4.5)
  • Downloading symfony/framework-bundle (v7.4.5)
  • Downloading symfony/dotenv (v7.4.0)
  • Downloading doctrine/deprecations (1.1.6)
  • Downloading doctrine/dbal (4.3.5)
  • Downloading symfony/doctrine-messenger (v7.4.5)
  • Downloading symfony/debug-bundle (v7.4.0)
  • Downloading symfony/console (v7.4.4)
  • Downloading symfony/asset (v7.4.4)
  • Downloading squirrelphp/twig-php-syntax (v1.13)
  • Downloading setasign/fpdi (v2.6.4)
  • Downloading brick/math (0.14.7)
  • Downloading ramsey/uuid (4.9.2)
  • Downloading paragonie/constant_time_encoding (v3.1.3)
  • Downloading phpseclib/phpseclib (3.0.49)
  • Downloading league/uri-interfaces (7.8.0)
  • Downloading league/uri (7.8.0)
  • Downloading lcobucci/jwt (5.6.0)
  • Downloading league/oauth2-server (9.3.0)
  • Downloading league/flysystem (3.31.0)
  • Downloading league/flysystem-local (3.31.0)
  • Downloading league/flysystem-memory (3.31.0)
  • Downloading smalot/pdfparser (v2.12.3)
  • Downloading phpstan/phpdoc-parser (2.3.2)
  • Downloading jms/metadata (2.9.0)
  • Downloading jms/serializer (3.32.6)
  • Downloading goetas-webservices/xsd2php-runtime (0.2.18)
  • Downloading horstoeko/zugferd (v1.0.120)
  • Downloading guzzlehttp/psr7 (2.8.0)
  • Downloading guzzlehttp/promises (2.3.0)
  • Downloading guzzlehttp/guzzle (7.10.0)
  • Downloading ezyang/htmlpurifier (v4.19.0)
  • Downloading dragonmantank/cron-expression (v3.6.0)
  • Downloading masterminds/html5 (2.10.0)
  • Downloading thecodingmachine/safe (v3.3.0)
  • Downloading sabberworm/php-css-parser (v9.1.0)
  • Downloading dompdf/php-svg-lib (1.0.2)
  • Downloading dompdf/php-font-lib (1.0.2)
  • Downloading doctrine/inflector (2.1.0)
  • Downloading composer/semver (3.4.4)
  • Downloading composer/composer (2.9.5)
  • Downloading composer/class-map-generator (1.7.1)
  • Downloading cocur/slugify (v4.7.1)
  • Downloading react/promise (v3.3.0)
  • Downloading marc-mabe/php-enum (v4.7.2)
  • Downloading justinrainbow/json-schema (6.6.4)
  • Downloading composer/ca-bundle (1.5.10)
  • Downloading ezimuel/guzzlestreams (4.1.0)
  • Downloading ezimuel/ringphp (1.4.0)
  • Downloading pentatrion/vite-bundle (v8.2.3)
  • Downloading shopware/administration (v6.7.7.1)
  • Downloading shyim/opensearch-php-dsl (1.1.3)
  • Downloading async-aws/core (1.28.0)
  • Downloading shopware/elasticsearch (v6.7.7.1)
  • Downloading meyfa/php-svg (v0.16.1)
  • Downloading shopware/storefront (v6.7.7.1)
  • Downloading shopware/paypal-sdk (v1.6.2)
    mmap() failed: [12] Cannot allocate memory
    Fatal error: Out of memory (allocated 103137280 bytes) (tried to allocate 446464 bytes) in phar:///homepages/42/d654425739/htdocs/quellsteinschmiede/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Json/JsonFile.php on line 183
    {„success“:false}
Zu wenig Arbeitsspeicher: Out of memory (allocated 103137280 bytes
103 MB ist auch etwas wenig Arbeitsspeicher. Shopware setzt 512MB voraus.
Danke für die info das dachte ich mir auch
ich musste im root verzeichnis einfach auf unendlich memory in der php.ini erhöhen jetzt geht es
da stand nix drinn
Danke
