Shopware Komponente erweitern TypeError: message.split is not a function
Schreibe gerade an einem Plugin und erhalte folgende Fehlermeldung in der Console TypeError: message.split is not a function found in <swproductmediaform>...
Die Komponente wird von mir überschrieben und um eine Funktion erweitert.
import template from './sw-product-media-form.html.twig';
const { Component } = Shopware;
Component.override('sw-product-media-form', {
    template,
    computed: {
        hoverCover() {
            if (!this.product) {
                return null;
            return this.product.media.find(media => media.id === this.product.hoverCoverId);
        currentHoverCoverID() {
            const hoverCoverMediaItem = this.productMedia.find(hoverCoverMedium =>
                hoverCoverMedium.media.id === this.product.hoverCoverId
            return hoverCoverMediaItem.id || null;
    methods: {
        createPlaceholderMedia(mediaItems) {
            return {
                ...this.$super('createPlaceholderMedia'),
                isHoverCover: false,
        removeHoverCover() {
            this.product.hoverCoverId = null;
        isHoverCover(productMedia) {
            if (this.product.media.length === 0) {
                return false;
            return productMedia.id === this.product.hoverCoverId;
        removeFile(productMedia) {
            // remove cover id if mediaId matches
            if (this.product.coverId === productMedia.id) {
                this.product.coverId = null;
            // remove hover cover id if mediaId matches
            if (this.product.hoverCoverId === productMedia.id) {
            this.product.media.remove(productMedia.id);
        markMediaAsHoverCover(productMedia) {
            this.product.hoverCoverId = (productMedia.productMediaId || productMedia.id);
            this.productFromStore.hoverCoverId = (productMedia.productMediaId || productMedia.id);
{% block sw_product_media_form_grid_items %}
{% endblock %}
Hab alles mögliche schon geprüft und kann den Fehler nicht finden.
