Hallo
Immer wenn ich auf die Shopware Hauptseite zugreifen will kommt folgende Meldung: 404 File Not Found
access.log
127.0.0.1 - - [31/Jul/2017:11:54:20 +0200] "GET / HTTP/1.0" 404
127.0.0.1 - - [31/Jul/2017:11:51:45 +0200] "GET /eula.txt HTTP/1.0" 200
Zugriff auf eula.txt funktioniert und zeigt die Datei an, also vermute ich auf ein .htaccess Problem.
Wenn ich im Hauptverzeichnis eine HTML Testseite anlege (index.html) erscheint diese auch problemlos.
htaccess:
RewriteEngine on
#RewriteBase /shopware/
# Https config for the backend
#RewriteCond %{HTTPS} !=on
#RewriteRule backend/(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
RewriteRule backend/media/(.*) media/$1 [NC,L]
RewriteCond %{REQUEST_URI} !(\/(engine|files|templates|themes|web)\/)
RewriteCond %{REQUEST_URI} !(\/media\/(archive|banner|image|music|pdf|unknown|video)\/)
RewriteRule ^(.*)$ shopware.php [PT,L,QSA]
# Fix missing authorization-header on fast_cgi installations
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
# Block access to VCS directories
RedirectMatch 404 /\\.(svn|git|hg|bzr|cvs)(/|$)
# Restrict access to root folder files
RedirectMatch 404 /(composer\.(json|lock)|README\.md|UPGRADE\.md)$
# Staging environment
#SetEnvIf Host "staging.test.shopware.in" SHOPWARE_ENV=staging
# Development environment
#SetEnvIf Host "dev.shopware.in" SHOPWARE_ENV=dev
#SetEnv SHOPWARE_ENV dev
DirectoryIndex index.html
DirectoryIndex index.php
DirectoryIndex shopware.php
# Disables download of configuration
# Deny all requests from Apache 2.4+.
Require all denied
# Deny all requests from Apache 2.0-2.2.
Deny from all
# Enable gzip compression
AddOutputFilterByType DEFLATE text/html text/xml text/plain text/css text/javascript application/javascript application/json
ExpiresActive on
ExpiresDefault "access plus 1 month"
Header append Cache-Control "public"
Header unset ETag
FileETag None
# Match generated files like:
# 1429684458_t22_s1.css
# 1429684458_t22_s1.js
Header set Cache-Control "max-age=31536000, public"
ExpiresActive on
ExpiresDefault "access plus 1 year"
# Disables auto directory index
Options -Indexes
Options -MultiViews
# php_value memory_limit 256M
# php_value max_execution_time 120
# php_value upload_max_filesize 20M
php_flag phar.readonly off
php_flag magic_quotes_gpc off
php_flag session.auto_start off
php_flag suhosin.session.cryptua off
php_flag zend.ze1_compatibility_mode off
php_value always_populate_raw_post_data -1
# AddType x-mapp-php5 .php
# AddHandler x-mapp-php5 .php
Header append X-Frame-Options SAMEORIGIN
Im vhost steht Allowoverride auf all:
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
