nach dem Shopware Update 5.7.3 ich habe folgendes Probleme:
Enlight_Controller_Exception: Unauthorized in /engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:212 Stack trace:
#0 /engine/Library/Enlight/Event/Handler/Plugin.php(155): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend()
#1 /engine/Library/Enlight/Event/EventManager.php(208): Enlight_Event_Handler_Plugin->execute()
#2 /engine/Library/Enlight/Controller/Action.php(161): Enlight_Event_EventManager->notify()
#3 /engine/Library/Enlight/Controller/Dispatcher/Default.php(461): Enlight_Controller_Action->dispatch()
#4 /engine/Library/Enlight/Controller/Front.php(225): Enlight_Controller_Dispatcher_Default->dispatch()
#5 /engine/Shopware/Kernel.php(192): Enlight_Controller_Front->dispatch()
#6 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Shopware\Kernel->handle()
#7 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(477): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle()
#8 /engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward()
#9 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(267): Shopware\Components\HttpCache\AppCache->forward()
#10 /engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass()
#11 /var/www/vhosts/geobest.de/httpdocs/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle()
#12
ODER:
Enlight_Exception: Invalid customergroup in /engine/Shopware/Controllers/Frontend/Register.php:464 Stack trace:
#0 /engine/Shopware/Controllers/Frontend/Register.php(489): Shopware_Controllers_Frontend_Register->getCustomerGroupKey()
#1 /engine/Shopware/Controllers/Frontend/Register.php(82): Shopware_Controllers_Frontend_Register->getRegisterData()
#2 /engine/Library/Enlight/Controller/Action.php(181): Shopware_Controllers_Frontend_Register->indexAction()
#9 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(450): Shopware\Components\HttpCache\AppCache->forward()
#10 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch()
#11 /engine/Shopware/Components/HttpCache/AppCache.php(188): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup()
#12 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(222): Shopware\Components\HttpCache\AppCache->lookup()
#13 /engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle()
#14 /var/www/vhosts/geobest.de/httpdocs/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle()
#15
was bedeutet das?
