Any ideas how to fix it? in this version?
Error
Received the following error message:
SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘ration’, ‘2018-09-18 14:42:49’, ‘2018-09-18 14:42:49’, 0), (‘backend/article/vie’ at line 1
Response
{“query”:,“success”:false,“offset”:“0”,“errorMsg”:“SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘ration’, ‘2018-09-18 14:42:49’, ‘2018-09-18 14:42:49’, 0), (‘backend/article/vie’ at line 1”}
