Hi, I need to create variants for article with selection, so next chioce must depends from before one, but in one step next choice must depends from result of before one. For example, STEP 1: Choose Color: white, black; STEP 2: Choose Type: Left, Right; STEP 3: Choose Model: here if choosen Left (in step before) then shows to choose L1 or L2, if choosen Right then shows to choose R1 or R2. I know that is can be set in SET DEPENDENCY, but unsuccesfull, tried several times. Thanks in advance!
Hello, You are on the right track. You can achieve this in two steps: [list=1] Set configurator dependencies Set configurator type to „Selection“ [/list] Following image should help you:
