Setting a shoppingworld as homepage
New to Shopware so excuse me if I’m asking either an old/double or just plain silly question…
How -if possible- can I set a shoppingworld as my main landingpage?  At the moment it’s set as rod-online.com/meprolight, which is OK I guess in combination with Adwords or whatever as I can pick landing page specifically there.  But how do I set it that rod-online.com has the shoppingworld as landing page?
In addition to this question: how and where can I edit the main landing page anyway??
Thanks
Open the Shoppingworld and go to Settings.
You can choose the category where to publish it.
In your case the highest category above.
Normally it is the Language Name of the Shop.
If you want to edit it choose the Pencil-Button.
If you want your Shoppingworld also at the place it is now:
You can copy/duplicate the shoppingworld you already have (Button with symbol two sheets of paper.
Then open it and under Setttings you can choose the category where to publish it.
Thanks Hammer,
Not entirely sure how I fixed it, fiddled around with it a bit and it seems making a copy and de-select “landing page” on the copy is what fixed it.  Thanks again
I have seen the result. Looks nice.
Still a long way to go, but I think we’ll be live in 7 days or so…
