Hallo, kann jemand weiterhelfen, ich kann mit diesen Meldungen immer nichts anfangen? Was kann ich tun, um das das Frontend wieder funktioniert. [quote] [Semantical Error] line 0, col 240 near ‘currencies LEFT’: Error: Class Shopware\Models\Shop\Shop has no association named currencies in vendor/doctrine/orm/lib/Doctrine/ORM/Query/QueryException.php on line 63 Stack trace: #0 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(483): Doctrine\ORM\Query\QueryException::semanticalError(‘line 0, col 240…’, Object(Doctrine\ORM\Query\QueryException)) #1 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(1042): Doctrine\ORM\Query\Parser->semanticalError(‘Class Shopware…’) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(1688): Doctrine\ORM\Query\Parser->JoinAssociationPathExpression() #3 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(1628): Doctrine\ORM\Query\Parser->JoinAssociationDeclaration() #4 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(1558): Doctrine\ORM\Query\Parser->Join() #5 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(1286): Doctrine\ORM\Query\Parser->IdentificationVariableDeclaration() #6 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(874): Doctrine\ORM\Query\Parser->FromClause() #7 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(843): Doctrine\ORM\Query\Parser->SelectStatement() #8 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(268): Doctrine\ORM\Query\Parser->QueryLanguage() #9 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Parser.php(351): Doctrine\ORM\Query\Parser->getAST() #10 vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(255): Doctrine\ORM\Query\Parser->parse() #11 vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(267): Doctrine\ORM\Query->_parse() #12 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(794): Doctrine\ORM\Query->_doExecute() #13 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(574): Doctrine\ORM\AbstractQuery->execute(NULL, 1) #14 Shopware/Models/Shop/Repository.php(327): Doctrine\ORM\AbstractQuery->getResult() #15 Shopware/Plugins/Default/Core/Router/Bootstrap.php(103): Shopware\Models\Shop\Repository->getActiveByRequest(Object(Enlight_Controller_Request_RequestHttp)) #16 Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Core_Router_Bootstrap->onRouteStartup(Object(Enlight_Controller_EventArgs)) #17 Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_EventArgs)) #18 Enlight/Controller/Front.php(170): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Object(Enlight_Controller_EventArgs)) #19 Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #20 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #21 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #22 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #23 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #24 Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #25 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #26 Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #27 shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #28 {main} [/quote]
Habe per FTP alle Chaches gelöscht, jetzt geht alles wieder. Weiß aber nicht, ob es daran gelegen hat.
