Rule Builder
Hello dear community,
unfortunately we are stuck and need your support.
Can you show us an example of how a setup with the Rule Builder works in terms of:
  1. Minimum quantity surcharge (Mindermengenzuschlag)
    If cart value <20€, then €5 surcharge
  2. Minimum order value (Mindestbestellwert)
    If cart value <20€, then display ‘You need to have at least 20€ cart value to order’
Thanks in advance!
The rule builder only describes a customer with his cart and can’t do any actions like surcharges or messages in the cart. There is no such functionality currently in the shopware core.
