In the account section it is possible to register your shops over http. Due to technical and security issues this is not possible for us.
Is there a possibilty to register the shop over https?
Check the following part in backend. Backend>Shop Settings> Shops > „Your Shop“ > and there on the right side you will see field for host and a checkbox for enabling/disabling SSL (https) support. Hope that helps.
