Problem with changes items.
Hi to all
I have a problem. I create an item and i save it after if i go to change somthing and go to save it i have this error : " An error occurred while attempting to save the item:The item has been changed in the meantime. To prevent overwriting these changes, saving the item was aborted. Please close the item and re-open it" and the product don’t saved.
Thanks a lot
This is a bug in the current version and will be fixed with 5.5.2
In the meantime you may fix it with the following PR -> SW-22619 - Fix timezone issues on overwrite check · shopware/shopware@d389efd · GitHub
Thanks Christiantrade i change the files but nothing change. I have the same problem
my shopware version is 5.5.1
Reload the backend. It should work, i had the same problem.
i reload bakend i clear chache bu the same my friend
yes its ok my friend maybe want some time to take the changes. thanks a lot thanks thanks
