Problem ordernumber
Ich bekomme seit heute morgen folgende Fehlermeldung (shopware 5.2.12)
Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. in vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php on line 781 Stack trace: #0 engine/Shopware/Controllers/Backend/Order.php(378): Doctrine\ORM\AbstractQuery->getOneOrNullResult(2) #1 engine/Shopware/Controllers/Backend/Order.php(347): Shopware_Controllers_Backend_Order->getList(NULL, Array, '0', '20') #2 var/cache/production_201611281529/proxies/ShopwareControllersBackendOrderProxy.php(6): Shopware_Controllers_Backend_Order->getListAction() #3 engine/Library/Enlight/Hook/HookManager.php(186): Shopware_Proxies_ShopwareControllersBackendOrderProxy->executeParent('getListAction', Array) #4 var/cache/production_201611281529/proxies/ShopwareControllersBackendOrderProxy.php(17): Enlight_Hook_HookManager->executeHooks(Object(Shopware_Proxies_ShopwareControllersBackendOrderProxy), 'getListAction', Object(Enlight_Hook_HookArgs)) #5 engine/Library/Enlight/Controller/Action.php(159): Shopware_Proxies_ShopwareControllersBackendOrderProxy->getListAction() #6 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('getListAction') #7 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #8 engine/Shopware/Kernel.php(178): Enlight_Controller_Front->dispatch() #9 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Enlight_Controller_Request_RequestHttp), 1, true) #10 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #12 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #13 shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #14 {main}
Das Problem liegt daran, das ordernumbers doppelt vergeben werden. Ich habe diese dann in der Tabelle s_order erst mal korrigiert, so das diese weiter fortlaufend sind. Was muss ich wo einstellen, damit die ordernumbers weiter fortlaufend erzeugt werden?
Das sollte eigentlich Standardmäßig so sein. Es kann in sehr, sehr seltenen Fällen einmal vorkommen. Mach mal eine Testbestellung, sollte eigentlich klappen.
