Hallo, wollte gerade Shopware auf Version 5.1 updaten, dann kam aber folgende Fehlermeldung: http://www.outdoorcamp24.de/recovery/up … x.php/done Weiß jemand was ich tun muss bzw. woran es liegt? Slim Application Error The application could not run because of the following error: Details Type: ErrorException Code: 2 Message: include(/home/www/p229776/html/shopware/engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php): failed to open stream: No such file or directory File: /home/www/p229776/html/shopware/recovery/common/vendor/composer/ClassLoader.php Line: 412 Trace #0 /home/www/p229776/html/shopware/recovery/common/vendor/composer/ClassLoader.php(412): Slim\Slim::handleErrors(2, ‘include(/home/w…’, ‘/home/www/p2297…’, 412, Array) #1 /home/www/p229776/html/shopware/recovery/common/vendor/composer/ClassLoader.php(412): Composer\Autoload\includeFile() #2 /home/www/p229776/html/shopware/recovery/common/vendor/composer/ClassLoader.php(301): Composer\Autoload\includeFile(’/home/www/p2297…’) #3 [internal function]: Composer\Autoload\ClassLoader->loadClass(‘Doctrine\ORM\Pe…’) #4 /home/www/p229776/html/shopware/vendor/doctrine/orm/lib/Doctrine/ORM/UnitOfWork.php(3009): spl_autoload_call(‘Doctrine\ORM\Pe…’) #5 /home/www/p229776/html/shopware/vendor/doctrine/orm/lib/Doctrine/ORM/EntityRepository.php(194): Doctrine\ORM\UnitOfWork->getEntityPersister(‘Shopware\Models…’) #6 /home/www/p229776/html/shopware/engine/Shopware/Components/Theme/Installer.php(241): Doctrine\ORM\EntityRepository->findOneBy(Array) #7 /home/www/p229776/html/shopware/engine/Shopware/Components/Theme/Installer.php(141): Shopware\Components\Theme\Installer->synchronizeThemeDirectories(Object(DirectoryIterator)) #8 /home/www/p229776/html/shopware/engine/Shopware/Components/Theme/Installer.php(117): Shopware\Components\Theme\Installer->synchronizeThemes() #9 /home/www/p229776/html/shopware/recovery/update/src/app.php(165): Shopware\Components\Theme\Installer->synchronize() #10 [internal function]: {closure}() #11 /home/www/p229776/html/shopware/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array) #12 /home/www/p229776/html/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch() #13 /home/www/p229776/html/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call() #14 /home/www/p229776/html/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call() #15 /home/www/p229776/html/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call() #16 /home/www/p229776/html/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call() #17 /home/www/p229776/html/shopware/recovery/update/index.php(46): Slim\Slim->run() #18 {main}
Hi, der Fehler steht doch da, das liegt an fehlenden Dateien.
Lg
ok, danke erstmal, aber woher soll ich diese fehlende Datei hernehmen? bzw. was soll ich dort einfügen?
Vermutlich stimmen auf deinem Server die Dateirechte nicht, wodurch beim Update nicht alle Dateien angelegt werden konnten. Welche Datei fehlt, steht ja in der Fehlermeldung. Shopware runterladen —> entpacken—>fehlenden Dateien manuell via FTB hochladen.
Lg
