Fehler nach/bei dem Update auf Shopware 5.1
Hallo zusammen, folgender Fehler ist bei einem Update einer Shopware 5.0.4 auf die 5.1 aufgetreten: Slim Application Error The application could not run because of the following error: Details Type: Doctrine\ORM\Mapping\MappingException Message: The target-entity Shopware\Models\Attribute\CustomerShipping cannot be found in 'Shopware\Models\Customer\Shipping#attribute'. File: /var/www/vhosts/SERVER/URL/shop/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/MappingException.php Line: 762 Trace #0 /var/www/vhosts/SERVER/URL/shop/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataInfo.php(1023): Doctrine\ORM\Mapping\MappingException::invalidTargetEntityClass('Shopware\Models...', 'Shopware\Models...', 'attribute') #1 /var/www/vhosts/SERVER/URL/shop/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataFactory.php(272): Doctrine\ORM\Mapping\ClassMetadataInfo-\>validateAssociations() #2 /var/www/vhosts/SERVER/URL/shop/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataFactory.php(251): Doctrine\ORM\Mapping\ClassMetadataFactory-\>validateRuntimeMetadata(Object(Doctrine\ORM\Mapping\ClassMetadata), NULL) #3 /var/www/vhosts/SERVER/URL/shop/vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/AbstractClassMetadataFactory.php(332): Doctrine\ORM\Mapping\ClassMetadataFactory-\>doLoadMetadata(Object(Doctrine\ORM\Mapping\ClassMetadata), NULL, false, Array) #4 /var/www/vhosts/SERVER/URL/shop/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataFactory.php(78): Doctrine\Common\Persistence\Mapping\AbstractClassMetadataFactory-\>loadMetadata('Shopware\Models...') #5 /var/www/vhosts/SERVER/URL/shop/vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/AbstractClassMetadataFactory.php(216): Doctrine\ORM\Mapping\ClassMetadataFactory-\>loadMetadata('Shopware\Models...') #6 /var/www/vhosts/SERVER/URL/shop/vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/AbstractClassMetadataFactory.php(115): Doctrine\Common\Persistence\Mapping\AbstractClassMetadataFactory-\>getMetadataFor('Shopware\Models...') #7 /var/www/vhosts/SERVER/URL/shop/engine/Shopware/Components/Model/ModelManager.php(305): Doctrine\Common\Persistence\Mapping\AbstractClassMetadataFactory-\>getAllMetadata() #8 /var/www/vhosts/SERVER/URL/shop/engine/Shopware/Components/Model/ModelManager.php(289): Shopware\Components\Model\ModelManager-\>regenerateAttributeProxies(Array) #9 /var/www/vhosts/SERVER/URL/shop/recovery/update/src/DependencyInjection/Container.php(176): Shopware\Components\Model\ModelManager-\>generateAttributeModels() #10 /var/www/vhosts/SERVER/URL/shop/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(112): Shopware\Recovery\Update\DependencyInjection\Container-\>Shopware\Recovery\Update\DependencyInjection\{closure}(Object(Pimple\Container)) #11 /var/www/vhosts/SERVER/URL/shop/recovery/update/src/DependencyInjection/Container.php(182): Pimple\Container-\>offsetGet('shopware.contai...') #12 /var/www/vhosts/SERVER/URL/shop/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(112): Shopware\Recovery\Update\DependencyInjection\Container-\>Shopware\Recovery\Update\DependencyInjection\{closure}(Object(Pimple\Container)) #13 /var/www/vhosts/SERVER/URL/shop/recovery/common/src/DependencyInjection/Container.php(80): Pimple\Container-\>offsetGet('shopware.theme\_...') #14 /var/www/vhosts/SERVER/URL/shop/recovery/update/src/app.php(164): Shopware\Recovery\Common\DependencyInjection\Container-\>get('shopware.theme\_...') #15 [internal function]: {closure}() #16 /var/www/vhosts/SERVER/URL/shop/recovery/common/vendor/slim/slim/Slim/Route.php(462): call\_user\_func\_array(Object(Closure), Array) #17 /var/www/vhosts/SERVER/URL/shop/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route-\>dispatch() #18 /var/www/vhosts/SERVER/URL/shop/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim-\>call() #19 /var/www/vhosts/SERVER/URL/shop/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash-\>call() #20 /var/www/vhosts/SERVER/URL/shop/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride-\>call() #21 /var/www/vhosts/SERVER/URL/shop/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions-\>call() #22 /var/www/vhosts/SERVER/URL/shop/recovery/update/index.php(46): Slim\Slim-\>run() #23 {main}
Hi, das scheint ein Fehler bei der Generierung der Attribute Models zu sein. Bitte lass diese einmal neu generieren. Entweder über die Clear Cache Funktion im Backend oder über das entsprechende Command Line Tool: bin/console sw:generate:attributes Hoffe das hilft dir weiter. Gruß Oliver
shop ist nach update im Wartungszustand ! kein anmelden mehr möglich ! bitte um Hilfe
Hi, @4tree.de Such bitte erst im Forum nach ähnlichen Threads. Das Problem wurde hier schon ein paar Mal behandelt. post118733.html?hilit=Wartungszustand#p118733 VG, Marcel
Danke… es musste der Ordner update gelöscht werden … jetzt geht wieder alles…
gibt es auch eine dritte Möglichkeit? Denn das Backend ist nicht erreichbar, 4tee.de Lösung funktioniert bei mir nicht und mit den Command Line Befehlen kann ich leider noch nichts anfangen. Wenn mir das jemand aber erläutern würde wo ich die Befehle eingebe, würde ich es gerne ausprobieren. Das sind ja keine Shell Befehle?
Hallo, führe mal das Reparaturscript aus: http://community.shopware.com/Foreign-K … l_954.html Danach den Cache über FTP umbenennen (also /cache/production…) und schauen ob die Models neu erzeugt werden. Moritz
