Power BI
Hi there,
Does anyone have tips on how to connect Shopware to Power BI?
Thank you in advance!
Mariana
What do you need to know?
PowerBI has a MySQL adapter and can read mysql databases. So it should be really easy to connect it.
indeed, or you export nightly the database to a destination and consume from there the data.
Just give Tableau also a try. https://www.tableau.com/de-de/products/desktop
kindly
Thank you for your help!
I’m not very familiar with Shopware, does it have a mysql connector as well?
yes, sure
