@NextMike schrieb:
Guck mal was der 500er genau sagt. Die Meldung müsstest Du aus den Serverlogs holen.
das logfile ist nur mit dieser meldung gefüllt
leider versteh ich nicht all zu viel
2016-10-25 13:22:53] core.ERROR: exception ‚Enlight_Controller_Exception‘ with message ‚Unauthorized‘ in /www/htdocs/w0119da8/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:202 Stack trace:
#0 /www/htdocs/
w0119da8/engine/Library/Enlight/Event/Handler/Plugin.php(149):
Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs)) #1 /www/htdocs/w0119da8/engine/Library/
Enlight/Event/EventManager.php(213):
Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs)) #2 /www/htdocs/w0119da8/engine/Library/Enlight/Controller/Action.php(137):
Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs)) #3 /www/htdocs/w0119da8/engine/Library/Enlight/Controller/Dispatcher/Default.php(523):
Enlight_Controller_Action-
>dispatch(‚getGrammarActio…‘) #4 /www/htdocs/w0119da8/engine/Library/Enlight/Controller/Front.php(226):
Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp),
Object(Enlight_Controller_Response_ResponseHttp)) #5 /www/htdocs/w0119da8/engine/Shopware/Kernel.php(153):
Enlight_Controller_Front->dispatch() #6 /www/htdocs/w0119da8/vendor/symfony/http-kernel/HttpCache/
HttpCache.php(492):
Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /www/htdocs/w0119da8/engine/Shopware/Components/HttpCache/AppCache.php(255):
Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /www/htdocs/w0119da8/vendor/symfony/http-kernel/HttpCache/HttpCache.php(263):
Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /www/htdocs/w0119da8/engine/Shopware/Components/HttpCache/AppCache.php(103):
Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 /www/htdocs/w0119da8/shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #11 {main} {„uid“:„6c5ffc6“}
