Hat schon jemand so einen Fehler gehabt?
Shop macht auf einmal Error 500 ![]()
PHP Fatal error: Uncaught Symfony\Component\Config\Definition\Exception\InvalidConfigurationException:
Unrecognized options "transports, routing" under "framework". Available options are "annotations", "asset_mapper", "assets", "cache", "csrf_protection", "default_locale", "disallow_search_engi ne_index", "enabled_locales", "error_controller", "esi", "exceptions", "form", "fragments", "handle_all_throwables", "html_sanitizer", "http_cache",
"http_client", "http_method_override", "ide", "lock", "mailer", "messenger", "notifier", "php_errors", "profiler", "property_access", "property_info", "rate_limiter", "remote-event", "request", "router", "scheduler", "secret", "secrets", "semaphore", "serializer", "session",
"set_content_language_from_locale", "set_locale_from_accept_language", "ssi", "test", "translator", "trust_x_sendfile_type_header", "trusted_headers", "trusted_hosts", "trusted_proxies", "uid", "validation", "web_link", "webhook",
"workflows". in /var/.../vendor/symfony/config/Defini tion/ArrayNode.php:327
