PDF Rechnung
Hallo
Versuche die Rechnung in /themes/Frontend/Cnctheme/documents/index.tpl anzupassen. Ja ich bin ein Neuling mit Shopware etc.
Ich habe von themes/Bare/documents/index.tpl kopiert und angepasst (Kundenadresse links anstelle von rechts).
Bei Vorschau:
Drücke erhalte ich die Meldung:
directory ‚/home/gug1/www/cnc/themes/Frontend/Cnctheme/documents/index.tpl‘ not allowed by security setting in engine/Library/Smarty/sysplugins/smarty_security.php on line 381
Stack trace:
 #0 engine/Library/Smarty/sysplugins/smarty\_internal\_resource\_file.php(33): Smarty\_Security-\>isTrustedResourceDir('/home/gug1/www/...') #1 engine/Library/Smarty/sysplugins/smarty\_resource.php(303): Smarty\_Internal\_Resource\_File-\>populate(Object(Smarty\_Template\_Source), NULL) #2 engine/Library/Smarty/sysplugins/smarty\_internal\_resource\_extends.php(41): Smarty\_Resource::source(NULL, Object(Enlight\_Template\_Manager), 'documents/../.....') #3 engine/Library/Enlight/Components/Snippet/Resource.php(76): Smarty\_Internal\_Resource\_Extends-\>populate(Object(Smarty\_Template\_Source), Object(Enlight\_Template\_Default)) #4 engine/Library/Smarty/sysplugins/smarty\_resource.php(303): Enlight\_Components\_Snippet\_Resource-\>populate(Object(Smarty\_Template\_Source), Object(Enlight\_Template\_Default)) #5 engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(636): Smarty\_Resource::source(Object(Enlight\_Template\_Default)) #6 engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(117): Smarty\_Internal\_Template-\>\_\_get('source') #7 engine/Shopware/Components/Document.php(252): Smarty\_Internal\_TemplateBase-\>fetch('documents/../.....', Object(Smarty\_Data)) #8 engine/Shopware/Controllers/Backend/Document.php(67): Shopware\_Components\_Document-\>render() #9 engine/Library/Enlight/Controller/Action.php(193): Shopware\_Controllers\_Backend\_Document-\>indexAction() #10 engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight\_Controller\_Action-\>dispatch('indexAction') #11 engine/Library/Enlight/Controller/Front.php(222): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #12 engine/Shopware/Kernel.php(215): Enlight\_Controller\_Front-\>dispatch() #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #15 vendor/symfony/http-kernel/HttpCache/HttpCache.php(253): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #16 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #17 shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #18 {main}
Wenn ich in der Datei smarty_security.php die Zeile 381 mit // Auskomentiere ist die Vorschau möglich!
Line 381 ist --> throw new SmartyException(„directory ‚{$_filepath}‘ not allowed by security setting“);
Ich finde keine Lösung… wo das Problem sein könnte :(
Hat jemand eine Idee?
Freundliche Grüsse
Christian
Dein Template Pfad ist sicher falsch.
Leite alles vom Bare Theme ab. Ich habe auch alle von links nach rechts geändert da in der Schweiz das so gemacht wird.
Gruss Chrigi
Gruss Chrigi
Hallo Chrigi
Danke für die Antwort, aber ich verstehe nicht was du mmit dem falschen Theme Path meinst
wo soll der Path falsch sein?
Gruss
Auch Chrigi oder Chrigel
Leite alles vom Original Index.tpl ab. Du kannst es ja in deinem Theme unter Belegerstellung (oder so) unten einstellen wie und wo deine Zeilen stehen sollen. ist eine aufwendige Sache bis alles für Dich passt. Aber funzt dann ganz sicher.
Grüssli Chrigi
Danke nützt alles nichts
habe in neues test.tpl mit PDF Belegerstellung angelegt. Nur mit :
 {$Containers.Logo.value}
bei der Vorschau erhalte ich die Fehlermeldung wie im ersten post. Mit den // in SMARTY sehe ich das Logo.
Grundeinstellungen->Shopeinstellungen->Shops->Dokumenten-Template gesetzt?
Wenn ja, dann muss bei deinem ersten Bildchen im Template nur index.tpl stehn und nicht dieser …/…/  Krempel
1000 Dank das war der Fehler. Falscher eintrag im ->Shops->Dokumenten-Template:
Danke
Christian
