Nach Update auf Shopware 5.2.2 kann ich keine Artikel mehr bearbeiten oder anlegen
Folgende Fehlermeldung erscheint:
Unable to load template snippet ‘backend/index/customizingjs.js|backend/index/bonus_menu_item.tpl|backend/plugin/base/header.tpl|backend/index/license.tpl|backend/index/paypal_header.tpl|backend/neti_foundation/extend/header/css.tpl’ in engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php on line 127
Stack trace:
#0 engine/Library/Enlight/View/Default.php(274): Smarty\_Internal\_TemplateBase-\>fetch()
 #1 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default))
 #2 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
 #3 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
 #4 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
 #5 engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
 #6 engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #7 engine/Library/Enlight/Controller/Action.php(202): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #8 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('indexAction')
 #9 engine/Library/Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #10 engine/Shopware/Kernel.php(176): Enlight\_Controller\_Front-\>dispatch()
 #11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #12 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #14 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
 #15 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #16 {main}
Vielleicht hat jemand dasselbe Problem und bereits gelöst? :slight_smile:
Custom Products ist nicht mit 5.2 kompatibel, da gibt es ein neues Plugin.
du musst das also deaktivieren, damit wieder alles läuft
Du bist ein Gott :slight_smile: Vielen Dank es hat funktioniert :slight_smile:
