Hallo Community,
ich hab edas Problem das ich nach dem Shopware Update auf 5.2 (Update von 4.3 auf 5 dann auf 5.2 und auf 5.2.3) nicht mehr in die Backend Einstellungen komme.
Es kommt immer diese Fehlermeldung :
unmatched {block} {/block} pairs in template file ‚backend/config/controller/license.js‘ in engine/Library/Smarty/sysplugins/smarty_internal_resource_extends.php on line 115
Stack trace:
#0 engine/Library/Enlight/Components/Snippet/Resource.php(169): Smarty\_Internal\_Resource\_Extends-\>getContent(Object(Smarty\_Template\_Source))
#1 engine/Library/Smarty/sysplugins/smarty\_resource.php(782): Enlight\_Components\_Snippet\_Resource-\>getContent(Object(Smarty\_Template\_Source))
#2 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(177): Smarty\_Template\_Source-\>\_\_get('content')
#3 engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(187): Smarty\_Internal\_TemplateCompilerBase-\>compileTemplate(Object(Enlight\_Template\_Default))
#4 engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(155): Smarty\_Internal\_Template-\>compileTemplateSource()
#5 engine/Library/Enlight/View/Default.php(274): Smarty\_Internal\_TemplateBase-\>fetch()
#6 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default))
#7 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
#8 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
#9 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
#10 engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs))
#11 engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
#12 engine/Library/Enlight/Controller/Action.php(202): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
#13 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('indexAction')
#14 engine/Library/Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
#15 engine/Shopware/Kernel.php(176): Enlight\_Controller\_Front-\>dispatch()
#16 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#17 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#18 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
#19 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
#20 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
#21 {main}
Hat von euch jmd eine Idee wo der Fehler liegt?
Ich habe das Update schon neu gemacht und es lief ohne Fehler durch.
Danke für eure Hilfe
Andre
