Nach Update Auf 5.7 Fehler aufgetreten
Guten Tag Freunde,
Ich habe mein Shop auf die Version 5.7 geupdatet
und bekomme diese Fehler Meldung
Fatal error : Uncaught Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException: The „dreisc_discount.bundle.service.promotion_service“ service or alias has been removed or inlined when the container was compiled. You should either make it public, or stop using the container directly and use dependency injection instead. in /var/www/vhosts/host/host/vendor/symfony/dependency-injection/Container.php:275 Stack trace: #0 /var/www/vhosts/fairvapedeals.de/test.fair-vape.de/vendor/symfony/dependency-injection/Container.php(231): Symfony\Component\DependencyInjection\Container->make() #1 /var/www/vhosts/host/host/engine/Shopware/Components/DependencyInjection/Container.php(210): Symfony\Component\DependencyInjection\Container->get() #2 /var/www/vhosts/host/host/engine/Shopware/Components/DependencyInjection/Container.php(134): Shopware\Components\DependencyInjection\Container->doLoad() #3 /var/www/vhosts/host/host/c in /var/www/vhosts/fairvapedeals.de/test.fair-vape.de/vendor/symfony/dependency-injection/Container.php on line 275
Danke schon mal im voraus
LG Max
Deaktiviere testweise mal das Plugin von Dreischild.
danke dir hat geklappt
