Nach PHP Update Bilderauswahl "defekt"
Nach dem Update auf PHP 7 (Version 5.5.4) kann ich beim Anlegen eines Artikels kein Bild mehr zuweisen, bzw allgemein auch bei diversen Plugins nicht mehr auf den Mediamanager zugreifen.
Folgende Fehlermeldung:
Unable to load template snippet ‘backend/media_manager/view/media/view.js’ in 'snippet:string:{include file=“backend/media_manager/model/album.js”}
{include file=“backend/media_manager/model/media.js”}
{include file=“backend/media_manager/model/setting.js”}
{include file=“backend/media_manager/view/album/add.js”}
{include file=“backend/media_manager/view/album/setting.js”}
{include file=“backend/media_manager/view/album/tree.js”}
{include file=“backend/media_manager/view/main/selection.js”}
{include file=“backend/media_manager/view/main/window.js”}
{include file=“backend/media_manager/view/media/view.js”}
{include file=“backend/media_manager/view/media/grid.js”}
{include file=“backend/media_manager/view/thumbnail/main.js”}
{include file=“backend/media_manager/view/batch_move/batch_move.js”}
{include file=“backend/media_manager/view/replace/window.js”}
{include file=“backend/media_manager/view/replace/grid.js”}
{include file=“backend/media_manager/view/replace/row.js”}
{include file=“backend/media_manager/view/replace/upload.js”}
{include file=“backend/media_manager/view/replace/file_select.js”}
{include file=“backend/media_manager/store/album.js”}
{include file=“backend/media_manager/store/media.js”}
{include file=“backend/media_manager/controller/main.js”}
{include file=“backend/media_manager/controller/album.js”}
{include file=“backend/media_manager/controller/media.js”}
{include file=“backend/media_manager/controller/thumbnail.js”}’ in engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php on line 127
Stack trace:
#0 engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(286): Smarty\_Internal\_TemplateBase-\>fetch(Object(Enlight\_Template\_Default), NULL, NULL, NULL, false, false, true)
 #1 var/cache/production\_201812030839/templates/backend\_de\_DE\_4b542/c8/4c/b3/c84cb3c9bde2a368f21c843fd982b4b0169df776.snippet.8de26b43fd19b2037c55895c3e5193027a2ff642.php(38): Smarty\_Internal\_Template-\>getSubTemplate('backend/media\_m...', NULL, 'backend\_de\_DE\_4...', NULL, NULL, Array, 0)
 #2 engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(180): content\_5c6c0b91ac5b38\_93317076(Object(Enlight\_Template\_Default))
 #3 engine/Library/Enlight/View/Default.php(300): Smarty\_Internal\_TemplateBase-\>fetch()
 #4 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default))
 #5 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
 #6 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
 #7 engine/Library/Enlight/Event/Handler/Default.php(91): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
 #8 engine/Library/Enlight/Event/EventManager.php(220): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #9 engine/Library/Enlight/Controller/Action.php(235): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #10 engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight\_Controller\_Action-\>dispatch('loadAction')
 #11 engine/Library/Enlight/Controller/Front.php(222): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #12 engine/Shopware/Kernel.php(202): Enlight\_Controller\_Front-\>dispatch()
 #13 vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #14 vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #15 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #16 vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #17 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
 #18 shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #19 {main}
Hat jemand eine Idee, was ich da machen kann? Außer Backup einspielen ;-)
Vielen Dank im Voraus. Grüße Anne-Kathrin
Entschuligung, dass das so fett erscheint :frowning: war keine Absicht, hatte es „nur“ reinkopiert
Sieht aus als wenn er was vermisst, schaue mal ob im Backend/ExtJs/backend/media_manager/view/media/ … die  view.js zu finden ist.
Auch mal wegen dem chmod schauen…
Ok, vielen Dank :slight_smile:
