Ich kann meinen Media Manager nicht mehr öffnen.
Ich sehe im Code etwas von Unable to load template snippet 'backend/media_manager/view/media/view.js
Aber im Ordner /themes/Backend/ExtJs/backend/media_manager/view/ oder /themes/Backend/ExtJs/backend/media_manager/ habe ich keinen Ordner mit den Namen “media”.
Was läuft hier wohl falsch?
Ich nutze Shopware 5.5.10 sowie den Media Adapter SFTP (Medien liegen auf einem externen Server). Dieser war bisher aber kein Problem.
Die Fehlermeldung findet ihr unten.
Vielen Dank für jede Hilfe.
Unable to load template snippet 'backend/media_manager/view/media/view.js' in 'snippet:string:{include file="backend/media_manager/model/album.js"}
{include file="backend/media_manager/model/media.js"}
{include file="backend/media_manager/model/setting.js"}
{include file="backend/media_manager/view/album/add.js"}
{include file="backend/media_manager/view/album/setting.js"}
{include file="backend/media_manager/view/album/tree.js"}
{include file="backend/media_manager/view/main/selection.js"}
{include file="backend/media_manager/view/main/window.js"}
{include file="backend/media_manager/view/media/view.js"}
{include file="backend/media_manager/view/media/grid.js"}
{include file="backend/media_manager/view/thumbnail/main.js"}
{include file="backend/media_manager/view/batch_move/batch_move.js"}
{include file="backend/media_manager/view/replace/window.js"}
{include file="backend/media_manager/view/replace/grid.js"}
{include file="backend/media_manager/view/replace/row.js"}
{include file="backend/media_manager/view/replace/upload.js"}
{include file="backend/media_manager/view/replace/file_select.js"}
{include file="backend/media_manager/store/album.js"}
{include file="backend/media_manager/store/media.js"}
{include file="backend/media_manager/controller/main.js"}
{include file="backend/media_manager/controller/album.js"}
{include file="backend/media_manager/controller/media.js"}
{include file="backend/media_manager/controller/thumbnail.js"}' in engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php on line 127
Stack trace:
#0 engine/Library/Smarty/sysplugins/smarty_internal_template.php(286): Smarty_Internal_TemplateBase->fetch(Object(Enlight_Template_Default), NULL, NULL, NULL, false, false, true)
#1 var/cache/production_201906060858/templates/backend_de_DE_6948c/c8/4c/b3/c84cb3c9bde2a368f21c843fd982b4b0169df776.snippet.8de26b43fd19b2037c55895c3e5193027a2ff642.php(38): Smarty_Internal_Template->getSubTemplate('backend/media_m...', NULL, 'backend_de_DE_6...', NULL, NULL, Array, 0)
#2 engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(180): content_5d7b4edf868fc1_68586807(Object(Enlight_Template_Default))
#3 engine/Library/Enlight/View/Default.php(300): Smarty_Internal_TemplateBase->fetch()
#4 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default))
#5 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#6 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#7 engine/Library/Enlight/Event/Handler/Default.php(91): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#8 engine/Library/Enlight/Event/EventManager.php(219): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#9 engine/Library/Enlight/Controller/Action.php(234): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#10 engine/Library/Enlight/Controller/Dispatcher/Default.php(563): Enlight_Controller_Action->dispatch('loadAction')
#11 engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#12 engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()
#13 vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#14 vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#15 engine/Shopware/Components/HttpCache/AppCache.php(260): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#16 vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#17 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#18 shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#19 {main}
