Kunden von SW 4.1.4 auf 5.0.3
Hallo Ich habe mein Shop neu mit SW 5.0.3 aufgebaut. Nun habe ich mein Alten Shop local auf mein Rechner kopiert. Habe den Alten Shop auf 4.2 updatet und dann auf 5.0.3 das hat alles super geklappt nun habe ich auf mein localen rechner die Kunden im Backent Exportiert. Jetzt möchte ich die Kunden in mein neuen Shop importieren. Leiter bekomme ich jetzt diese Fehlermeldung [quote]Errors: Error in line 1: Shop by id not found Error in line 2: Shop by id not found Error in line 3: Shop by id not found Error in line 4: Shop by id not found Error in line 5: Shop by id not found Error in line 6: Shop by id not found Error in line 7: Shop by id not found Error in line 8: Shop by id not found Error in line 9: Shop by id not found Error in line 10: Shop by id not found Error in line 11: Shop by id not found Error in line 12: Shop by id not found Error in line 13: Shop by id not found Error in line 14: Shop by id not found Error in line 15: Shop by id not found Error in line 16: Shop by id not found Error in line 17: Shop by id not found Error in line 18: Shop by id not found Error in line 19: Shop by id not found Error in line 20: Shop by id not found Error in line 21: Shop by id not found Error in line 22: Shop by id not found Error in line 23: Shop by id not found Error in line 24: Shop by id not found Error in line 25: Shop by id not found Error in line 26: Shop by id not found Error in line 27: Shop by id not found Error in line 28: Shop by id not found Error in line 29: Shop by id not found Error in line 30: Shop by id not found Error in line 31: Shop by id not found Error in line 32: Shop by id not found Error in line 33: Shop by id not found Error in line 34: Shop by id not found Error in line 35: Shop by id not found Error in line 36: Shop by id not found Error in line 37: Shop by id not found Error in line 38: Shop by id not found Error in line 39: Shop by id not found Error in line 40: Shop by id not found Error in line 41: Shop by id not found Error in line 42: Shop by id not found Error in line 43: Shop by id not found Error in line 44: Shop by id not found Error in line 45: Shop by id not found Error in line 46: Shop by id not found Error in line 47: Shop by id not found Error in line 48: Shop by id not found Error in line 49: Shop by id not found Error in line 50: Shop by id not found Error in line 51: Shop by id not found Error in line 52: Shop by id not found Error in line 53: Shop by id not found Error in line 54: Shop by id not found Error in line 55: Shop by id not found Error in line 56: Shop by id not found Error in line 57: Shop by id not found Error in line 58: Shop by id not found Error in line 59: Shop by id not found Error in line 60: Shop by id not found Error in line 61: Shop by id not found Error in line 62: Shop by id not found Error in line 63: Shop by id not found Error in line 64: Shop by id not found Error in line 65: Shop by id not found Error in line 66: Shop by id not found Error in line 67: Shop by id not found Error in line 68: Shop by id not found Error in line 69: Shop by id not found Error in line 70: Shop by id not found Error in line 71: Shop by id not found Error in line 72: Shop by id not found Error in line 73: Shop by id not found Error in line 74: Shop by id not found Error in line 75: Shop by id not found Error in line 76: Shop by id not found[/quote] was habe ich falsch gemacht? Gruß Mattes
Naja der Fehler steht doch da. Die ID des Shops passt nicht zusammen mit deinen Import bzw. der Shop ID im Import.
Und wie kann ich das ändern? Ich hatte zum Test einen Test kunden angelegt diese habe ich aus den backend wieder gelöscht
Stimmen denn die Shop IDs überein? Steht glaube ich in der s_core_shops oder sowas.
die Shop ID steht in s_core_shop_currencies die ist auf dem Localen und auf mein Server auf 1 shop_ID = 1
Ich habe nun noch Einträge von Test kunden gesehen. s_core_payment_instance s_order s_order_billingaddress s_order_shippingaddress die habe ich auch alle gelöscht leider immer noch das selbe problem
Hallo Ich habe das jetzt Manuell in phpmyadmin gemacht. Habe die User Tabellen gelöscht und die mit meinen Kunden Importiert. Nun kommt leider die Fehlermeldung wenn der Kunde sich einlogen möchte [quote]Ups! Ein Fehler ist aufgetreten! Wir wurden bereits über das Problem informiert und arbeiten an einer Lösung, bitte versuchen Sie es in Kürze erneut.[/quote] Woran kann das jetzt liegen? Gruß Mattes
