Kleinere Fehler nach Update von 5.5.10 auf 5.6.8
Ich habe wegen der performence mich dazu entschlossen unseren Shop upzudaten.
Soweit hat es auch alles geklappt.
Im Backend kann ich leider nun den Cache nicht mehr aufwärmen lassen .
Irgendeine Idee?
vielen lieben Dank
Gruß Nico
anbei ein kleiner auszug der Log datei
[2020-09-17 11:31:25] core.CRITICAL: An exception occurred while executing 'SELECT id as id, ordernumber, details FROM s_articles_details': SQLSTATE(42S22): Column not found: 1054 Unknown column 'details' in 'field list' [] {"uid":"007c063"}
[2020-09-17 11:32:12] core.CRITICAL: An exception occurred while executing 'SELECT id as id, ordernumber, details FROM s_articles_details': SQLSTATE(42S22): Column not found: 1054 Unknown column 'details' in 'field list' [] {"uid":"007c063"}
[2020-09-17 11:32:44] core.ERROR: PDOException: SQLSTATE(42S22): Column not found: 1054 Unknown column 'details' in 'field list' in /customers/9/8/c/aomweb.de/httpd.www/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:912 Stack trace: #0 /customers/9/8/c/aomweb.de/httpd.www/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(912): PDO->query('SELECT id as id...') #1 /customers/9/8/c/aomweb.de/httpd.www/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(847): Doctrine\DBAL\Connection->executeQuery('SELECT id as id...', Array, Array) #2 /customers/9/8/c/aomweb.de/httpd.www/engine/Shopware/Bundle/SearchBundleDBAL/SearchTerm/SearchIndexer.php(149): Doctrine\DBAL\Connection->fetchAll('SELECT id as id...') #3 /customers/9/8/c/aomweb.de/httpd.www/engine/Shopware/Bundle/SearchBundleDBAL/SearchTerm/SearchIndexer.php(105): Shopware\Bundle\SearchBundleDBAL\SearchTerm\SearchIndexer->build() #4 /customers/9/8/c/aomweb.de/httpd.www/engine/Shopware/Bundle/SearchBundleDBAL/SearchTerm/SearchTermQueryBuilder.php(66): Shopware\Bundle\SearchBundleDBAL\SearchTerm\SearchIndexer->validate() #5
