SQLSTATE[42S22]: Column not found: 1054
Bei der Ausführung des cron kommt folgende Fehlermeldung und Ich komme nicht weiter bin dahingehend ein Neuling was Shopware betrifft und benötige Hilfe.
 Status: 503 Output:
## Ups! Ein Fehler ist aufgetreten!
### An exception occurred while executing 'SELECT (SELECT articleID FROM s\_articles\_details WHERE id = articledetailsID LIMIT 1) as id, Blumig FROM s\_articles\_attributes': SQLSTATE[42S22]: Column not found: 1054 Unknown column 'Blumig' in 'field list' in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 179
### Stack trace:
    #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(150): Doctrine\DBAL\DBALException::wrapException(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), 'An exception oc...') #1 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(915): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), 'SELECT (SELECT ...', Array) #2 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(847): Doctrine\DBAL\Connection-\>executeQuery('SELECT (SELECT ...', Array, Array) #3 engine/Shopware/Bundle/SearchBundleDBAL/SearchTerm/SearchIndexer.php(149): Doctrine\DBAL\Connection-\>fetchAll('SELECT (SELECT ...') #4 engine/Shopware/Plugins/Default/Frontend/CronRefresh/Bootstrap.php(99): Shopware\Bundle\SearchBundleDBAL\SearchTerm\SearchIndexer-\>build() #5 engine/Library/Enlight/Event/Handler/Plugin.php(145): Shopware\_Plugins\_Frontend\_CronRefresh\_Bootstrap-\>onCronJobSearch(Object(Shopware\_Components\_Cron\_CronJob)) #6 engine/Library/Enlight/Event/EventManager.php(251): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Shopware\_Components\_Cron\_CronJob)) #7 engine/Library/Enlight/Components/Cron/Manager.php(275): Enlight\_Event\_EventManager-\>notifyUntil('Shopware\_CronJo...', Object(Shopware\_Components\_Cron\_CronJob)) #8 engine/Shopware/Plugins/Default/Core/Cron/Cron.php(53): Enlight\_Components\_Cron\_Manager-\>runJob(Object(Enlight\_Components\_Cron\_Job)) #9 engine/Library/Enlight/Controller/Action.php(192): Shopware\_Controllers\_Backend\_Cron-\>indexAction() #10 engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight\_Controller\_Action-\>dispatch('indexAction') #11 engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #12 engine/Shopware/Kernel.php(188): Enlight\_Controller\_Front-\>dispatch() #13 vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true) #15 engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #16 vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #17 engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #18 shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #19 {main}
Der Shop läuft auf 5.6.6 und wurde erst for 2 Wochen auf einem v Server ( Managed ) umgezogen
