Klarna Payments Invalid Token (BestIt)
Hi, ich habe Klarna Payments installiert, den Zahlungsarten und Versandarten hinterlegt.
Im Checkout wird bei diesen Zahlungsarten dann „display: none“ gemacht und in der Chrome Console steht:
api.js:1 Uncaught InvalidClientTokenError: The client token is invalid. Make sure it has not been tampered with in any way.
    at new t (https://x.klarnacdn.net/kp/lib/v1/api.js:1:4154)
    at Object.init (https://x.klarnacdn.net/kp/lib/v1/api.js:1:27488)
    at window.klarnaAsyncCallback (https://example.de/checkout/shippingPayment:701:17)
    at i (https://x.klarnacdn.net/kp/lib/v1/api.js:1:40477)
    at r (https://x.klarnacdn.net/kp/lib/v1/api.js:1:40268)
    at Object. (https://x.klarnacdn.net/kp/lib/v1/api.js:1:39605)
    at t (https://x.klarnacdn.net/kp/lib/v1/api.js:1:101)
    at https://x.klarnacdn.net/kp/lib/v1/api.js:1:452
    at https://x.klarnacdn.net/kp/lib/v1/api.js:1:462
Hat jemand eine Idee wo der Fehler ist?
Danke und Gruss.
SW: 5.6.6
PHP: 7.2.30
Und beim Offcanvas Warenkorb kommt beim klick:
1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:854 Uncaught ReferenceError: Klarna is not defined
    at Plugin.loadInstantShoppingButton (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:854)
    at Plugin.init (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:854)
    at PluginBase (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:144)
    at new Plugin (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:152)
    at HTMLDivElement. (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:152)
    at Function.each (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:5)
    at k.fn.init.each (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:5)
    at k.fn.init.pluginFn [as bestitInstantShoppingLoadButton] (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:152)
    at EventEmitter._initSinglePlugin (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:193)
    at EventEmitter._initPlugin (1592334401_964fc7d7100fdd6b8fa0e96684637b79.js:190)
und im Error-Log(System)
Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException: You have requested a non-existent service "bestit_klarna_order_management.sw_modules.s_articles". Did you mean one of these: "bestit_klarna_order_management.guzzle_http.client", "bestit_klarna_order_management.sw_modules.detached_shop", "bestit_klarna_order_management.sw_modules.s_admin", "bestit_klarna_order_management.sw_modules.s_basket"? in /vendor/symfony/dependency-injection/Container.php:348 Stack trace:
#0 /engine/Shopware/Components/DependencyInjection/Container.php(220): Symfony\Component\DependencyInjection\Container->get('bestit_klarna_o...', 1)
#1 /engine/Shopware/Components/DependencyInjection/Container.php(141): Shopware\Components\DependencyInjection\Container->doLoad('bestit_klarna_o...', 'bestit_klarna_o...', 1)
#2 /engine/Library/Enlight/Controller/Action.php(413): Shopware\Components\DependencyInjection\Container->get('bestit_klarna_o...')
#3 /custom/plugins/BestitKlarnaPayments/Controllers/Frontend/BestitKlarnaInstantShopping.php(86): Enlight_Controller_Action->get('bestit_klarna_o...')
#4 /engine/Library/Enlight/Controller/Action.php(183): Shopware_Controllers_Frontend_BestitKlarnaInstantShopping->preDispatch()
#5 /engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch('previewKlarnaIn...')
#6 /engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#7 /engine/Shopware/Kernel.php(188): Enlight_Controller_Front->dispatch()
#8 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#9 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#10 /engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#11 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(426): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#13 /engine/Shopware/Components/HttpCache/AppCache.php(188): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#15 /engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#16 /www/htdocs/w019afb4/example.de/shop/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#17
Es gibt keinen “bestit_klarna_order_management.sw_modules.s_articles”, es gäbe ein “bestit_klarna_order_management.sw_modules.s_admin”. Ist das der Fehler?
Hallo.
Leider besteht das Problem immer noch. Der Shop ist mittlerweile auf SW 5.6.9,
Im Checkout stehen keine Klarna Payments zur Verfügung. Diese blitzen nur kurz auf.
Bug: Im Kundenkonto lässt sich die Klarna Zahlart auswählen, Geht man dann auf Kasse, landet man in einer deathloop der Zahlungsarten bis man ein ggf vorhandene (Vorkasse) auswählt.
Danke und Gruss
Habe genau das gleiche Problem.
Shopware 5.6.9, Klarna Payments Modul V. 1.4.1, PHP 7.4.13, auf einer nginx Hosting Umgebung.
Im Logfile (BestitKlarnaPayments) stehen immer wieder die gleichen zwei Zeilen:
HTTP/1.1 403 Forbidden Date: Thu, 03 Dec 2020 13:48:04 GMT Content-Type: application/json Content-Length: 130 Connection: keep-alive Server: openresty Vary: Accept-Encoding Render-Time: 23 Klarna-Correlation-Id: a2ef47b2-0c3d-4b48-8ab1-4838abc8ebd3 Strict-Transport-Security: max-age=31536000; includeSubDomains
POST /payments/v1/sessions HTTP/1.1 Host: api.klarna.com Accept: application/json Content-Type: application/json User-Agent: Shopware 5.6.9/BestitKlarnaPayments 1.4.1 Authorization: REMOVED Content-Length: 1486
Im Klarna Protokoll steht:
error_code: INVALID_OPERATION
Hier noch die Fehler aus dem System-Log (core_production)
Unable to write file "/var/www/clients/client1/web10/web/sw5/var/cache/production_202011060821/proxies/ShopwareComponentsModelModelRepositoryProxy.php"
Enlight_Exception: Unable to write file "/var/www/clients/client1/web10/web/sw5/var/cache/production_202011060821/proxies/ShopwareComponentsModelModelRepositoryProxy.php" in /engine/Library/Enlight/Hook/ProxyFactory.php:405 Stack trace:
#0 /engine/Library/Enlight/Hook/ProxyFactory.php(118): Enlight_Hook_ProxyFactory->writeProxyClass()
#1 /engine/Library/Enlight/Hook/HookManager.php(146): Enlight_Hook_ProxyFactory->getProxy()
#2 /engine/Shopware/Components/Model/ProxyAwareRepositoryFactory.php(81): Enlight_Hook_HookManager->getProxy()
#3 /engine/Shopware/Components/Model/ProxyAwareRepositoryFactory.php(62): Shopware\Components\Model\ProxyAwareRepositoryFactory->createRepository()
#4 /vendor/doctrine/orm/lib/Doctrine/ORM/EntityManager.php(713): Shopware\Components\Model\ProxyAwareRepositoryFactory->getRepository()
#5 /custom/plugins/SwagPaymentPayPalUnified/Components/Services/SettingsService.php(73): Doctrine\ORM\EntityManager->getRepository()
#6 /custom/plugins/SwagPaymentPayPalUnified/Subscriber/ExpressCheckout.php(137): SwagPaymentPayPalUnified\Components\Services\SettingsService->getSettings()
#7 /engine/Library/Enlight/Event/Handler/Default.php(87): SwagPaymentPayPalUnified\Subscriber\ExpressCheckout->addExpressCheckoutButtonCart()
#8 /engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute()
#9 /engine/Library/Enlight/Controller/Action.php(211): Enlight_Event_EventManager->notify()
#10 /engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch()
#11 /engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch()
#12 /engine/Shopware/Kernel.php(188): Enlight_Controller_Front->dispatch()
#13 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle()
#14 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle()
#15 /engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward()
#16 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(426): Shopware\Components\HttpCache\AppCache->forward()
#17 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(317): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch()
#18 /engine/Shopware/Components/HttpCache/AppCache.php(188): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup()
#19 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache->lookup()
#20 /engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle()
#21 /var/www/clients/client1/web10/web/sw5/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle()
#22
Hi
Gleiches Problem … :o/
Gab/gibt es eurerseits hier eine Lösung?
Lösung: Wir haben uns gegen Klarna/BestIT entschieden.
Bei uns hat es geholfen, einmal alle Browser-Cookies + LocalStorages zu leeren.
Cool. Das werde ich allen Kunden sagen :wink:
Hey, kannst du mir sagen welches Plugin ihr stattdessen benutzt habt?
Der Fehler wurde von meinem Kollegen gefunden und beseitigt und wir haben uns dagegen entschieden es zu veröffentlichen nachdem BestIT zu frech wurde.
kannst du uns irgendwie an der Lösung teilhaben lassen?
LG
Hi, hänge leider genau am selben Fehler, scheint ja von Seiten BestIT nix passiert zu sein…
Wäre super, wenn ihr eure Lösung teilen könnten :slight_smile:
LG Philipp
Problem besteht auch bei Klarna Payments 2.0 und Shopware 5.7.6 weiterhin … faszinierend. Wäre dennoch an einer Lösung interessiert.
wäre ebenfalls an der Lösung interessiert, da von bestit aus ja scheinbar nichts passieren wird
Wie kann es sein nach 3 Jahren, dass dieser Fehler immer noch auftritt. :confused:
