Kein Zugriff ins Backend möglich...
Wer kann bei diesem Fehler helfen?
Resource id ‘staging’ already exists in the ACL in Zend/Acl.php on line 298
Stack trace:
#0 Shopware/Components/Acl.php(61): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initAclResources() #2 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(493): Shopware\_Components\_Acl-\>initShopwareAclTree(Object(Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql)) #3 Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAcl(Object(Enlight\_Event\_EventArgs)) #4 Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #5 Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #6 Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(307): Shopware\_Bootstrap-\>getResource('Acl') #9 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(476): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 Shopware/Controllers/Backend/ExtJs.php(162): Enlight\_Application-\>\_\_call('Auth', Array) #17 Shopware/Controllers/Backend/ExtJs.php(162): Shopware-\>Auth() #18 Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 Shopware/Kernel.php(145): Enlight\_Controller\_Front-\>dispatch() #22 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(471): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(242): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main}
Hi, in der s_core_acl_resources ist anscheinend der Eintrag „staging“ doppelt, das müsstest du einmal korrigieren. Besten Gruß, Daniel
Einfach löschen?
habe ich nun mal versucht…hat nichts gebracht
