Update 5.0.1 zu 5.0.2
Nach dem Update kommt im Backend kein Login Fenster mehr, Console Fehler GET http://tcgshop.ch/backend/base?file=bootstrap&201507160826 ext-all.js?201507160826:21 Uncaught Error: Ext.Loader is not enabled, so dependencies cannot be resolved dynamically. Missing required class: Shopware.container.Viewport http://tcgshop.ch/backend/base?file=boo … 1507160826 Error [code]
Resource id ‘theme’ already exists in the ACL in Zend/Acl.php on line 298
Stack trace:
#0 Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 cache/production\_201507160826/proxies/ShopwareProductionProjectContainer.php(254): Shopware\_Components\_Acl-\>\_\_construct(Object(Shopware\Components\Model\ModelManager)) #4 vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(327): ShopwareProductionProjectContainer-\>getAclService() #5 Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('acl') #6 Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(305): Shopware\_Bootstrap-\>getResource('Acl') #9 Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(475): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #17 Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #18 Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #22 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main}
[/code] Frontend Console Fehler Uncaught TypeError: Cannot read property 'ajax\_add\_article' of undefined Probiert bisher: Cache per FTP gelöscht Update von ZIP Datei eingespielt Plugins in Datenbank deaktiviert Teil der LOG Datei [2015-08-14 10:26:37] core.ERROR: exception 'Zend\_Acl\_Exception' with message 'Resource id 'theme' already exists in the ACL' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Zend/Acl.php:298 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/proxies/ShopwareProductionProjectContainer.php(254): Shopware\_Components\_Acl-\>\_\_construct(Object(Shopware\Components\Model\ModelManager)) #4 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(327): ShopwareProductionProjectContainer-\>getAclService() #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('acl') #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(305): Shopware\_Bootstrap-\>getResource('Acl') #9 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(475): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #17 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #18 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #22 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main} [] {"uid":"8b68643"} [2015-08-14 10:26:56] core.ERROR: exception 'Zend\_Acl\_Exception' with message 'Resource id 'theme' already exists in the ACL' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Zend/Acl.php:298 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/proxies/ShopwareProductionProjectContainer.php(254): Shopware\_Components\_Acl-\>\_\_construct(Object(Shopware\Components\Model\ModelManager)) #4 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(327): ShopwareProductionProjectContainer-\>getAclService() #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('acl') #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(305): Shopware\_Bootstrap-\>getResource('Acl') #9 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(475): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #17 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #18 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #22 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main} [] {"uid":"36481a1"} [2015-08-14 10:27:09] core.ERROR: exception 'Zend\_Acl\_Exception' with message 'Resource id 'theme' already exists in the ACL' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Zend/Acl.php:298 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/proxies/ShopwareProductionProjectContainer.php(254): Shopware\_Components\_Acl-\>\_\_construct(Object(Shopware\Components\Model\ModelManager)) #4 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(327): ShopwareProductionProjectContainer-\>getAclService() #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('acl') #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(305): Shopware\_Bootstrap-\>getResource('Acl') #9 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(475): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #17 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #18 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #22 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main} [] {"uid":"2334b23"} [2015-08-14 10:28:07] core.ERROR: exception 'Exception' with message 'Referer check for backend session failed' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:441 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceBackendSession(Object(Enlight\_Event\_EventArgs)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #3 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(168): Shopware\Components\DependencyInjection\Container-\>load('BackendSession') #4 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(466): Shopware\_Bootstrap-\>loadResource('BackendSession') #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #8 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #9 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #10 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #17 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #19 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #20 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #21 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #22 {main} [] {"uid":"915075c"} [2015-08-14 10:28:24] core.ERROR: exception 'Zend\_Acl\_Exception' with message 'Resource id 'theme' already exists in the ACL' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Zend/Acl.php:298 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/proxies/ShopwareProductionProjectContainer.php(254): Shopware\_Components\_Acl-\>\_\_construct(Object(Shopware\Components\Model\ModelManager)) #4 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(327): ShopwareProductionProjectContainer-\>getAclService() #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('acl') #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(305): Shopware\_Bootstrap-\>getResource('Acl') #9 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(475): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #17 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #18 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #22 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main} [] {"uid":"87593bf"} [2015-08-14 13:16:39] core.ERROR: exception 'Zend\_Acl\_Exception' with message 'Resource id 'theme' already exists in the ACL' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Zend/Acl.php:298 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/proxies/ShopwareProductionProjectContainer.php(254): Shopware\_Components\_Acl-\>\_\_construct(Object(Shopware\Components\Model\ModelManager)) #4 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(327): ShopwareProductionProjectContainer-\>getAclService() #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('acl') #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(305): Shopware\_Bootstrap-\>getResource('Acl') #9 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(475): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #17 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #18 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #22 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main} [] {"uid":"8538f1c"} [2015-08-14 13:16:58] core.ERROR: exception 'Zend\_Acl\_Exception' with message 'Resource id 'theme' already exists in the ACL' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Zend/Acl.php:298 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/proxies/ShopwareProductionProjectContainer.php(254): Shopware\_Components\_Acl-\>\_\_construct(Object(Shopware\Components\Model\ModelManager)) #4 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(327): ShopwareProductionProjectContainer-\>getAclService() #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('acl') #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(305): Shopware\_Bootstrap-\>getResource('Acl') #9 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(475): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #17 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #18 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #22 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main} [] {"uid":"96e0b51"} [2015-08-14 13:18:03] core.ERROR: exception 'Zend\_Acl\_Exception' with message 'Resource id 'theme' already exists in the ACL' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Zend/Acl.php:298 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/proxies/ShopwareProductionProjectContainer.php(254): Shopware\_Components\_Acl-\>\_\_construct(Object(Shopware\Components\Model\ModelManager)) #4 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(327): ShopwareProductionProjectContainer-\>getAclService() #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('acl') #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(305): Shopware\_Bootstrap-\>getResource('Acl') #9 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(475): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #17 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #18 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #22 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main} [] {"uid":"52c55b8"} [2015-08-14 13:47:30] core.ERROR: exception 'ReflectionException' with message 'Class Shopware\Models\Attribute\CustomerGroup does not exist' in /var/www/vhosts/tcgshop.ch/httpdocs/vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/RuntimeReflectionService.php:74 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/RuntimeReflectionService.php(74): ReflectionClass-\>\_\_construct('Shopware\\Models...') #1 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataInfo.php(888): Doctrine\Common\Persistence\Mapping\RuntimeReflectionService-\>getClass('Shopware\\Models...') #2 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataFactory.php(537): Doctrine\ORM\Mapping\ClassMetadataInfo-\>wakeupReflection(Object(Doctrine\Common\Persistence\Mapping\RuntimeReflectionService)) #3 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/AbstractClassMetadataFactory.php(209): Doctrine\ORM\Mapping\ClassMetadataFactory-\>wakeupReflection(Object(Doctrine\ORM\Mapping\ClassMetadata), Object(Doctrine\Common\Persistence\Mapping\RuntimeReflectionService)) #4 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/EntityManager.php(295): Doctrine\Common\Persistence\Mapping\AbstractClassMetadataFactory-\>getMetadataFor('Shopware\\Models...') #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Doctrine/ORM/Persisters/BasicEntityPersister.php(1269): Doctrine\ORM\EntityManager-\>getClassMetadata('Shopware\\Models...') #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Doctrine/ORM/Persisters/BasicEntityPersister.php(1147): Doctrine\ORM\Persisters\BasicEntityPersister-\>getSelectColumnsSQL() #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Doctrine/ORM/Persisters/BasicEntityPersister.php(766): Doctrine\ORM\Persisters\BasicEntityPersister-\>getSelectSQL(Array, NULL, 0, NULL, NULL, NULL) #8 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Proxy/ProxyFactory.php(172): Doctrine\ORM\Persisters\BasicEntityPersister-\>load(Array, Object(Shopware\Proxies\_\_CG\_\_\Shopware\Models\Customer\Group)) #9 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/doctrine/proxies/\_\_CG\_\_ShopwareModelsCustomerGroup.php(208): Doctrine\ORM\Proxy\ProxyFactory-\>Doctrine\ORM\Proxy\{closure}(Object(Shopware\Proxies\_\_CG\_\_\Shopware\Models\Customer\Group), 'getKey', Array) #10 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/doctrine/proxies/\_\_CG\_\_ShopwareModelsCustomerGroup.php(208): Closure-\>\_\_invoke(Object(Shopware\Proxies\_\_CG\_\_\Shopware\Models\Customer\Group), 'getKey', Array) #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bundle/StoreFrontBundle/Service/Core/ContextService.php(179): Shopware\Proxies\_\_CG\_\_\Shopware\Models\Customer\Group-\>getKey() #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Models/Shop/Shop.php(711): Shopware\Bundle\StoreFrontBundle\Service\Core\ContextService-\>initializeShopContext() #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Core/Router/Bootstrap.php(129): Shopware\Models\Shop\Shop-\>registerResources(Object(Shopware\_Proxies\_ShopwareBootstrapProxy)) #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Core\_Router\_Bootstrap-\>onRouteStartup(Object(Enlight\_Controller\_EventArgs)) #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Controller\_EventArgs)) #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(162): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_EventArgs)) #17 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #18 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #19 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #20 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(447): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #21 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(347): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #22 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #23 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(211): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #24 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #25 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #26 {main} [] {"uid":"5153eb8"} [2015-08-14 13:48:02] core.ERROR: exception 'Zend\_Acl\_Exception' with message 'Resource id 'theme' already exists in the ACL' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Zend/Acl.php:298 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 /var/www/vhosts/tcgshop.ch/httpdocs/cache/production\_201507160826/proxies/ShopwareProductionProjectContainer.php(254): Shopware\_Components\_Acl-\>\_\_construct(Object(Shopware\Components\Model\ModelManager)) #4 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(327): ShopwareProductionProjectContainer-\>getAclService() #5 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('acl') #6 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('acl') #7 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container-\>get('Acl') #8 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(305): Shopware\_Bootstrap-\>getResource('Acl') #9 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(475): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>registerAclPlugin(Object(Shopware\_Components\_Auth)) #10 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Backend\_Auth\_Bootstrap-\>onInitResourceAuth(Object(Enlight\_Event\_EventArgs)) #11 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Event/EventManager.php(252): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Event\_EventArgs)) #12 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(247): Enlight\_Event\_EventManager-\>notifyUntil('Enlight\_Bootstr...', Array) #13 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/DependencyInjection/Container.php(142): Shopware\Components\DependencyInjection\Container-\>load('auth') #14 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Bootstrap.php(124): Shopware\Components\DependencyInjection\Container-\>has('Auth') #15 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Application.php(452): Shopware\_Bootstrap-\>hasResource('Auth') #16 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Enlight\_Application-\>\_\_call('Auth', Array) #17 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Controllers/Backend/ExtJs.php(160): Shopware-\>Auth() #18 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_ExtJs-\>indexAction() #19 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight\_Controller\_Action-\>dispatch('indexAction') #20 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Kernel.php(143): Enlight\_Controller\_Front-\>dispatch() #22 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 /var/www/vhosts/tcgshop.ch/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 /var/www/vhosts/tcgshop.ch/httpdocs/shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main} [] {"uid":"1a6df61"} [2015-08-14 16:45:08] core.ERROR: exception 'Zend\_Acl\_Exception' with message 'Resource id 'theme' already exists in the ACL' in /var/www/vhosts/tcgshop.ch/httpdocs/engine/Library/Zend/Acl.php:298 Stack trace: #0 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(68): Zend\_Acl-\>addResource(Object(Shopware\Models\User\Resource)) #1 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(51): Shopware\_Components\_Acl-\>initAclResources() #2 /var/www/vhosts/tcgshop.ch/httpdocs/engine/Shopware/Components/Acl.php(43): Shopware\_Components\_Acl-\>initShopwareAclTree() #3 Hab 5.0.2 in 2 Shops auf selben host von 5.0.1 geupdated, beim einem ohne Probleme, beim 2. geht nix mehr :confused: Irgendwelche Ideen?
Hallo, du hast wahrscheinlich vorher einmal das ACL/Benutzerrolle “theme” manuell angelegt. Der Updater legt es nochmal an, da dies mit 5.0.2 eingeführt wurde. Du musst “theme” also vor dem Update entweder löschen oder nach dem Update aus der Datenbank entfernen. Also aus der s_core_acl_resources einfach einen der beiden theme-Einträge löschen. Moritz
Hallo Moritz, danke erstmal für die schnelle Hilfe. Hab einen der beiden Einträge nun gelöscht, Backend und Frontend machen allerdings immer noch Probleme. Bin gerade dabei den Cache per FTP zu löschen (hab leider kein SSH Zugriff) Mal schauen obs danach geht
Problem mit dem Frontend und Backend ist leider nicht behoben.
Hi, hast du immernoch die Meldung „[2015-08-14 10:26:37] core.ERROR: exception ‚Zend_Acl_Exception‘ with message ‚Resource id ‚theme‘ already exists in the ACL‘“ oder eine von den anderen? Ist in der s_core_acl_resources wirklich nur noch ein Eintrag? Ggf. einmal ein Backup ziehen und alle „theme“-Einträge entfernen - nur, um das sicher auszuschließen. Schönen Gruß, Daniel
Musste noch swagupdate löschen welche auch doppelt vorhanden war, jetzt läuft wieder alles. Danke für die Hilfe :thumbup:
