Item description too long!
Hello everybody,
i have a problem with the bills. The short description is also listed under the item designation.
How can I delete the fact that only the article description is there?
I found the following line in the template index.tpl:
{block name = “document_index_table_name”}
             {$ position.name | nl2br}
{/block}
What do I have to do here?
Hi, not sure from your question if you want to have an article description in your invoices or not. Anyway, you can find instructions how to modify the document templates here: https://developers.shopware.com/designers-guide/edit-newsletter-and-document-templates/#edit-document-templates
Cheers, Phil
