I’m facing an issue while creating a custom SELECT field in Shopware 6 using a plugin. The custom field is being created successfully, but when I attempt to use the SELECT field in the category settings, the dropdown options appear empty. Instead of showing the expected „ON“ and „OFF“ options, the dropdown displays two empty values.
<?php declare(strict_types=1);
namespace MyNameSpace;
use Shopware\Core\Framework\Plugin\Context\ActivateContext;
use Shopware\Core\Framework\Context;
use Shopware\Core\Framework\Plugin;
use Shopware\Core\System\CustomField\CustomFieldTypes;
use Shopware\Core\Defaults;
use Shopware\Core\Framework\DataAbstractionLayer\EntityRepositoryInterface;
use Shopware\Core\Framework\DataAbstractionLayer\Search\Criteria;
class MyClass extends Plugin
public function activate(ActivateContext $activateContext): void
parent::activate($activateContext);
$context = $activateContext->getContext();
$this->createCustomField($context);
private function createCustomField(Context $context): void
$customFieldRepository = $this->container->get('custom_field_set.repository');
$customFieldData = [
'name' => 'categoryNoteSet',
'config' => [
'label' => [
'en-GB' => 'Categories Notes',
'de-DE' => 'Kategorien Hinweise',
Defaults::LANGUAGE_SYSTEM => "Categories Notes"
'relations' => [
'entityName' => 'category'
'customFields' => [
// ... Other custom fields
'name' => 'noteOfferActivate',
'type' => CustomFieldTypes::SELECT,
'config' => [
'label' => [
'en-GB' => 'Activate Offer note',
'de-DE' => 'Angebot Hinweis aktivieren',
Defaults::LANGUAGE_SYSTEM => "Note Text"
'options' => [
'label' => [
'en-GB' => 'ON',
'de-DE' => 'An',
'value' => 'true',
'label' => [
'en-GB' => 'OFF',
'de-DE' => 'Aus',
'value' => 'false',
'customFieldPosition' => 5
$customFieldRepository->create([$customFieldData], $context);
that’s how it looks:
Problem Details:
- I’m creating a custom SELECT field in Shopware 6 using the provided code.
- The custom field creation is successful with two options: „ON“ and „OFF.“
- However, upon accessing category settings, the dropdown field for the SELECT option displays two empty values instead of the expected „ON“ and „OFF“ options.
I would greatly appreciate any assistance or guidance on how to resolve this issue. Thank you for your support!
