hallo, wollte grade einen Import von der exportierten Artikel.CSV machen. da kommt folgende Fehlermeldung beim hochladen der CSV. eine “articleID” taucht in meiner CSV nicht auf?! [quote]Errors: Error in line 3: SQLSTATE[23000]: Integrity constraint violation: 1048 Column ‘articleID’ cannot be null Error in line 4: The EntityManager is closed. Error in line 5: The EntityManager is closed. Error in line 6: Category by id 10 not found Error in line 7: The EntityManager is closed. Error in line 8: The EntityManager is closed. Error in line 9: The EntityManager is closed. Error in line 10: The EntityManager is closed. Error in line 11: Category by id 11 not found Error in line 12: The EntityManager is closed. Error in line 13: The EntityManager is closed. Error in line 14: The EntityManager is closed. Error in line 15: The EntityManager is closed. Error in line 16: Category by id 12 not found Error in line 17: Category by id 10 not found Error in line 18: The EntityManager is closed. Error in line 19: The EntityManager is closed. Error in line 20: The EntityManager is closed. Error in line 21: Category by id 13 not found Error in line 22: Category by id 11 not found Error in line 23: The EntityManager is closed. Error in line 24: The EntityManager is closed. Error in line 25: The EntityManager is closed. Error in line 26[/quote] was ist da passiert ?
Hallo, wir arbeiten zurzeit an einer Lösung: installation-einstieg-f54/import-kunden-kategorien-artikel-aus-version-3-5-6-t8268.html Danke und Gruß Benjamin
