Installation von datenbank bei Shopware 6 Installation nicht möglich
Schönen guten Morgen zusammen.
Ich versuche nun schon seid einiger Zeit Shopware 6 auf meinen Webgo Webspace zu bekommen. Bei der Installation im Punkte Datenbank bricht er mit dieser Meldung ab: Kann mir jemand helfen ?
LG
Error
Received an error message.
URL: importDatabase
Message: Internal Server Error
Response
Slim Application Error
The application could not run because of the following error:Details
Type: RuntimeExceptionMessage: Identifier DB not initialized yetFile: /home/www/vendor/shopware/recovery/Install/src/ContainerProvider.phpLine: 111Trace
#0 /home/www/vendor/shopware/recovery/Common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider::Shopware\Recovery\Install\{closure}(Object(Slim\Container))
#1 /home/www/vendor/shopware/recovery/Install/src/ContainerProvider.php(163): Pimple\Container->offsetGet('db')
#2 /home/www/vendor/shopware/recovery/Common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider::Shopware\Recovery\Install\{closure}(Object(Slim\Container))
#3 /home/www/vendor/shopware/recovery/Install/src/ContainerProvider.php(192): Pimple\Container->offsetGet('dbal')
#4 /home/www/vendor/shopware/recovery/Common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider::Shopware\Recovery\Install\{closure}(Object(Slim\Container))
#5 /home/www/vendor/shopware/recovery/Install/src/app.php(537): Pimple\Container->offsetGet('migration.colle...')
#6 [internal function]: Closure->{closure}(Object(Slim\Http\Request), Object(Slim\Http\Response), Array)
#7 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(40): call_user_func(Object(Closure), Object(Slim\Http\Request), Object(Slim\Http\Response), Array)
#8 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/Route.php(281): Slim\Handlers\Strategies\RequestResponse->__invoke(Object(Closure), Object(Slim\Http\Request), Object(Slim\Http\Response), Array)
#9 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/MiddlewareAwareTrait.php(117): Slim\Route->__invoke(Object(Slim\Http\Request), Object(Slim\Http\Response))
#10 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/Route.php(268): Slim\Route->callMiddlewareStack(Object(Slim\Http\Request), Object(Slim\Http\Response))
#11 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/App.php(503): Slim\Route->run(Object(Slim\Http\Request), Object(Slim\Http\Response))
#12 /home/www/vendor/shopware/recovery/Install/src/app.php(158): Slim\App->__invoke(Object(Slim\Http\Request), Object(Slim\Http\Response))
#13 [internal function]: Closure->{closure}(Object(Slim\Http\Request), Object(Slim\Http\Response), Object(Slim\App))
#14 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/DeferredCallable.php(57): call_user_func_array(Object(Closure), Array)
#15 [internal function]: Slim\DeferredCallable->__invoke(Object(Slim\Http\Request), Object(Slim\Http\Response), Object(Slim\App))
#16 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/MiddlewareAwareTrait.php(70): call_user_func(Object(Slim\DeferredCallable), Object(Slim\Http\Request), Object(Slim\Http\Response), Object(Slim\App))
#17 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/MiddlewareAwareTrait.php(117): Slim\App->Slim\{closure}(Object(Slim\Http\Request), Object(Slim\Http\Response))
#18 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/App.php(392): Slim\App->callMiddlewareStack(Object(Slim\Http\Request), Object(Slim\Http\Response))
#19 /home/www/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/App.php(297): Slim\App->process(Object(Slim\Http\Request), Object(Slim\Http\Response))
#20 /home/www/vendor/shopware/recovery/Install/index.php(51): Slim\App->run()
#21 /home/www/public/recovery/install/index.php(6): require_once('/home/www/vendo...')
#22 {main}
Shopware benötigt in der php.ini eine max_execution_time von 30 Sekunden und ich hatte zu viel. Jetzt lief er durch, aber will danach wieder die selbe Installationsroutine durchführen als wäre nichts gewesen. Aber die Datenbank wurde richtig befüll…
Selbe Problem hier. Wie war die Lösung? Teilweise läuft die Installation durch und es scheint zu klappen. Dann aber bei neuladen der Seite
der Installationsstartbildschirm…
