Imports on Shopware 5
Just starting to kick off with Shopware 5 and testing the advanced import module. For some reason the input price doesn’t update and defaults to 1€ and it won’t assign to the category. If anyone has any tips I’ appreciate it.
Dan
I am note aware of any general issue in that regard, so I’d guess that this might be some kind of mapping problem? Which profile are you using - a default or a custom one? How are you importing - with XML or CSV? I guess we need to see profile and example import to get an impression what could be wrong here…
best regards,
Daniel
