Hallo, seit geräumer Zeit erhalte ich per E-Mail mit dem Betreff „Error in Shop“ immer wieder die folgende Fehlermeldung. Kann mir jemand sagen, was es bedeutet? Viele Grüße! [code]
ERROR
| Message: |
exception 'Enlight\_Controller\_Exception' with message 'Action "Frontend\_Checkout\_checkoutAction" not found failure' in /var/www/vhosts/homepage.de/httpdocs/homepage\_de/engine/Library/Enlight/Controller/Action.php:389 Stack trace: #0 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/engine/Library/Enlight/Controller/Action.php(159): Enlight\_Controller\_Action-\>\_\_call('checkoutAction', Array) #1 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Proxies\_ShopwareControllersFrontendCheckoutProxy-\>checkoutAction() #2 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('checkoutAction') #3 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #4 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/engine/Shopware/Kernel.php(145): Enlight\_Controller\_Front-\>dispatch() #5 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(471): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #6 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #7 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(428): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #8 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(328): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #9 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /var/www/vhosts/homepage.de/httpdocs/homepage\_de/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #13 {main}
| Time: |
2015-10-27T07:31:45.666022+0100
| Channel: |
core
| request: |
{ "uri": "/checkout/checkout", "method": "GET", "query": { "controller": "checkout", "action": "checkout" }, "post": [] }
| session: |
{ "sessionId": "10dab6f11d566531e972a6800ea08e6aaff23552", "Bot": false, "sOutputNet": false, "sRegister": [], "sUserId": null, "sCountry": null, "sState": null }
| shopId: |
1
| shopName: |
Deutsch
[/code]
Ich muss mir also keine sorgen wegen den Fehlermeldungen machen? Trotzdem komisch, denn in der Fehlermeldung steht ja auch etwas von “checkout” - ich mache mir sorgen, dass Kunden etwas bestellen möchten und beim Checkout etwas nicht klappt und die Bestellung abgebrochen wird. Ich selbst habe aber schon mehrere Testbestellungen gemacht und alles funktioniert einwandfrei.
