Hi there
I’m developing a backend plugin and I’m trying to understand how to apply valitations to my form. I checked out the Ext JS documentation for model definition :http://www.objis.com/formationextjs/lib/extjs-4.0.0/docs/api/Ext.data.Model.html
Based on that my model/sales_representative.js looks like:
Ext.define('Shopware.apps.SalesRepresentative.model.SalesRepresentative', {
extend: 'Shopware.data.Model',
configure: function() {
return {
controller: 'SalesRepresentative',
detail: 'Shopware.apps.SalesRepresentative.view.detail.SalesRepresentative'
fields: [
{ name : 'id', type: 'int', useNull: true},
{ name : 'firstName', type: 'string' },
{ name : 'lastName', type: 'string' },
{ name : 'email', type: 'string' },
{ name : 'salutation', type: 'string', useNull: true },
{ name : 'image', type: 'string', useNull: true },
{ name : 'assignable', type: 'boolean' }
validations: [
{ field: 'firstName', type: 'length', min: 1},
{ field: 'lastName', type: 'length', min: 1},
{ field: 'email', type: 'presence'},
{ field: 'email', type: 'format', matcher:/^\w+([-+.']\w+)*@\w+([-.]\w+)*\.\w+([-.]\w+)*$/,
message:'{s name=valitation_email_format}Wrong Email Format{/s}'}
If I try to save my form, validations don’t work and I can save independently I have firstName filled or a wrong email format.
Then I was searching aroung Shopware code and I saw that on Backend/ExtJs/backend/customer/view/detail/base.js the fields are created from scratch there on
createBaseForm function.
So the question is, what is the best/easy approach to apply validations to our forms? Is it possible without have to create form fields from scratch?
Thanks
