How can I reslove this(Failed to generate key) error on local system?
I’m trying to install Shopware 6 locally with WAMP without any Docker, In the requirements it’s getting error "JwtCertificateGenerationException - Failed to generate key ".
Can you please help me on this.
Thanks
Hi and welcome to the forums!
Best advice you’ll ever get for installation of web software: hands off of Windows, use any unix based system instead or docker/vm etc…
Please note that Shopware is not designed to run on a Windows server.
Hi @marco.steinhaeuser,
Thank you.
