How can I remove the two links that appear under the product description?
Hello!
> Do you have any questions concerning this product?
> Further products
Thank you!
You have to remove the block “frontend_detail_description_links”.
Create a new theme, and make a new file named ‘description.tpl’ in the folder frontend/detail/tabs in your theme (look at Bare/frontend folder structure) with the following content:
{extends file="parent:frontend/detail/tabs/description.tpl"}
{* Empty the links in the description *}
{block name='frontend_detail_description_links'}
{/block}
Activate your new theme, clear the cache, and links should no longer display.
Thank You very much!
Your answered really helped me.
