Hilfe! Code 2
Ich habe schon  2 mal alles heruntergeladen, installiert, den Datenbank erfolgreich übernommen. Bei letzem „Konfigurieren“ immer sehe diesen Bericht, wie kann ich das fixen?
Slim Application Error
Type:  ErrorException
Code:  2
Message:  „continue“ targeting switch is equivalent to „break“. Did you mean to use „continue 2“?
File:  C:\xampp\htdocs\Shopware\vendor\doctrine\orm\lib\Doctrine\ORM\UnitOfWork.php
Line:  2636
Trace
#0 C:\xampp\htdocs\Shopware\recovery\common\vendor\composer\ClassLoader.php(444): Slim\Slim::handleErrors(2, ‚„continue“ targ…‘, ‚C:\xampp\htdocs…‘, 2636, Array)
#1 C:\xampp\htdocs\Shopware\recovery\common\vendor\composer\ClassLoader.php(444): include()
#2 C:\xampp\htdocs\Shopware\recovery\common\vendor\composer\ClassLoader.php(322): Composer\Autoload\includeFile(‚C:\xampp\htdocs…‘)
#3 [internal function]: Composer\Autoload\ClassLoader->loadClass(‚Doctrine\ORM\Un…‘)
#4 C:\xampp\htdocs\Shopware\vendor\doctrine\orm\lib\Doctrine\ORM\EntityManager.php(160): spl_autoload_call(‚Doctrine\ORM\Un…‘)
#5 C:\xampp\htdocs\Shopware\engine\Shopware\Components\Model\ModelManager.php(86): Doctrine\ORM\EntityManager->__construct(Object(Doctrine\DBAL\Connection), Object(Shopware\Components\Model\Configuration), Object(Doctrine\Common\EventManager))
#6 C:\xampp\htdocs\Shopware\engine\Shopware\Components\DependencyInjection\Bridge\Models.php(74): Shopware\Components\Model\ModelManager::createInstance(Object(Doctrine\DBAL\Connection), Object(Shopware\Components\Model\Configuration), Object(Doctrine\Common\EventManager))
#7 C:\xampp\htdocs\Shopware\var\cache\production_201902250948\proxies\ShopwareProductionda39a3ee5e6b4b0d3255bfef95601890afd80709ProjectContainer.php(1679): Shopware\Components\DependencyInjection\Bridge\Models->factory(Object(Doctrine\Common\EventManager), Object(Shopware\Components\Model\Configuration), Object(Enlight_Loader), Object(Doctrine\DBAL\Connection), Object(Doctrine\ORM\Mapping\Driver\AnnotationDriver))
#8 C:\xampp\htdocs\Shopware\vendor\symfony\dependency-injection\Container.php(306): ShopwareProductionda39a3ee5e6b4b0d3255bfef95601890afd80709ProjectContainer->getModelsService()
#9 C:\xampp\htdocs\Shopware\engine\Shopware\Components\DependencyInjection\Container.php(211): Symfony\Component\DependencyInjection\Container->get(‚models‘, 1)
#10 C:\xampp\htdocs\Shopware\engine\Shopware\Components\DependencyInjection\Container.php(143): Shopware\Components\DependencyInjection\Container->doLoad(‚models‘, 1)
#11 C:\xampp\htdocs\Shopware\recovery\install\src\ContainerProvider.php(125): Shopware\Components\DependencyInjection\Container->get(‚models‘)
#12 C:\xampp\htdocs\Shopware\recovery\common\vendor\pimple\pimple\src\Pimple\Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#13 C:\xampp\htdocs\Shopware\recovery\install\src\ContainerProvider.php(131): Pimple\Container->offsetGet(‚shopware.contai…‘)
#14 C:\xampp\htdocs\Shopware\recovery\common\vendor\pimple\pimple\src\Pimple\Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#15 C:\xampp\htdocs\Shopware\recovery\install\src\ContainerProvider.php(144): Pimple\Container->offsetGet(‚shopware.theme_…‘)
#16 C:\xampp\htdocs\Shopware\recovery\common\vendor\pimple\pimple\src\Pimple\Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#17 C:\xampp\htdocs\Shopware\recovery\install\src\app.php(500): Pimple\Container->offsetGet(‚theme.service‘)
#18 [internal function]: {closure}()
#19 C:\xampp\htdocs\Shopware\recovery\common\vendor\slim\slim\Slim\Route.php(468): call_user_func_array(Object(Closure), Array)
#20 C:\xampp\htdocs\Shopware\recovery\common\vendor\slim\slim\Slim\Slim.php(1355): Slim\Route->dispatch()
#21 C:\xampp\htdocs\Shopware\recovery\common\vendor\slim\slim\Slim\Middleware\Flash.php(85): Slim\Slim->call()
#22 C:\xampp\htdocs\Shopware\recovery\common\vendor\slim\slim\Slim\Middleware\MethodOverride.php(92): Slim\Middleware\Flash->call()
#23 C:\xampp\htdocs\Shopware\recovery\common\vendor\slim\slim\Slim\Middleware\PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#24 C:\xampp\htdocs\Shopware\recovery\common\vendor\slim\slim\Slim\Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#25 C:\xampp\htdocs\Shopware\recovery\install\index.php(75): Slim\Slim->run()
#26 {main}
Hallo elena351,
ich hatte heute mit Shopware 5.5.7 auf meinem lokalen Rechner dasselbe Problem:
Line: 2636
Auch eine erneute Installation (per Komplett-Shop-ZIP-Datei bzw. One-File-Installer) brachte keine Besserung, weil alle dasselbe enthalten bzw. laden.
LÖSUNG: Ich habe also in der Datei "\vendor\doctrine\orm\lib\Doctrine\ORM\UnitOfWork.php" in der genannten Zeile und in einer weiteren, die dasselbe Problem aufwies, mittels Editor das „continue;“ in ein „continue 2;“ umgewandelt. Und die Seite neugeladen.
Seither funktioniert meine lokale Installation tadellos.
Moin!
Da ich das selbe im Log stehen habe und hier Abhilfe angeboten wird: Was tut denn diese Lösung?
Bekommt dann jeder Kunde 2 Gutscheine statt einem oder wird der Steuersatz geändert? :slight_smile:
Etwas Erhellung wäre toll… Danke!
Erik
Shopware Installationen auf lokalen Windows PC (C:\xampp) ist nicht gut. Es spiegelt nicht die Anforderungen auf einem richtigen Server wieder. Lieber irgendwo eine Subdomain einrichten und dort Shopware installieren.
Das Problem ist die PHP Version, vermutlich wird hier PHP 7.3 o. höher verwendet. Dies geht aber nicht mit SW 5.5.x
