Hello,
Can anyone tell where the scripts are loaded in the header just before the meta data. I would like to turn them off, but I do not know where they are called
Hello,
I think those scripts are specified in your Theme.php file, there’s a section called javascript, it’s an array including all the different files. You may need to check the theme you’re extending as well
* Javascript files which will be used in the theme.
* @var array
protected $javascript = [
// Third party plugins / libraries
'src/js/vendors/modernizr/modernizr.custom.35977.js',
'vendors/js/jquery/jquery.min.js',
'vendors/js/picturefill/picturefill.min.js',
'vendors/js/jquery.transit/jquery.transit.js',
'vendors/js/jquery.event.move/jquery.event.move.js',
'vendors/js/jquery.event.swipe/jquery.event.swipe.js',
'vendors/js/flatpickr/flatpickr.min.js',
// Shopware specific plugins
'src/js/jquery.plugin-base.js',
'src/js/jquery.state-manager.js',
'src/js/jquery.storage-manager.js',
'src/js/jquery.off-canvas-menu.js',
'src/js/jquery.search.js',
'src/js/jquery.tab-menu.js',
'src/js/jquery.image-slider.js',
I did not find them there. It's a bit weird because if I'm previewing the page via ctrl + u, there are no scripts. Only ctrl + shift + j shows these scripts.
Do you have any module installed that could be including those scripts? Something to manage google analytics and/or facebook?
I found the google tag manager plugin, so I’m looking for it here.
