Greeting everyone
We have encountered a huge problem. The Frosh profiler, which helps us to locate an elements file location has stopped working, even after reinstalling it.
And also, after every change (mostly in less files), I have to clear the shop cache, including the theme part, in order to see the changes I have made. These two problems tend to come in pair, since it keeps hapenning to us very often. I hope someone has a solution, because this is a very serious and annoying problem.
Thank you so much in advancefrosh
Have you enabled http cache / production mode?
Yes, I did, but we realized that our the problem is in our server, not SW itself.
The profiler is not compatible with the http cache
