Ich möchte ein Plugin installieren und bekommen diesen Fehler:
Das Plugin konnte aufgrund der Fehlermeldung „An exception occurred while executing ’ ALTER TABLE dreisc_seo_redirect_import_export_log ADD CONSTRAINT json.dreisc_seo_redirect_import_export_log.row_value CHECK (JSON_VALID(row_value)), ADD CONSTRAINT json.dreisc_seo_redirect_import_export_log.errors CHECK (JSON_VALID(errors)), ADD KEY fk.dreisc_seo_redirect_import_export_log.dreisc_seo_redirect_id (dreisc_seo_redirect_id), ADD CONSTRAINT fk.dreisc_seo_redirect_import_export_log.dreisc_seo_redirect_id FOREIGN KEY (dreisc_seo_redirect_id) REFERENCES dreisc_seo_redirect (id) ON DELETE CASCADE ON UPDATE CASCADE; ': SQLSTATE[HY000]: General error: 1005 Can’t create table c1_test.dreisc_seo_redirect_import_export_log (errno: 150 „Foreign key constraint is incorrectly formed“)“ nicht installiert werden
