Hallo!
Warum startet der FirstRunWizard immer wieder von neuem? Liegt es daran, dass eine Shopware-ID noch nicht eingegeben wurde?
Grüße
Hallo!
Grüße
Gibt es eine Fehlermeldung im Error-Log der Website oder in den Shopware-Logs?
Es gibt im Shopware-Log eine Fehlermeldung:
[2017-02-12 19:23:31] core.ERROR: exception ‚PDOException‘ with message ‚SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‚966-1‘ for key ‚element_id_shop_id‘‘ in /srv/www/htdocs/shopware/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:987 Stack trace: #0 /srv/www/htdocs/shopware/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(987): PDOStatement->execute() #1 /srv/www/htdocs/shopware/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(102): Doctrine\DBAL\Connection->executeUpdate(‚INSERT INTO s_c…‘, Array) #2 /srv/www/htdocs/shopware/engine/Shopware/Bundle/PluginInstallerBundle/Service/UniqueIdGenerator/UniqueIdGenerator.php(61): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator->storeUniqueIdInDb(‚eBRKtGBij0FBI8X…‘) #3 /srv/www/htdocs/shopware/engine/Shopware/Bundle/PluginInstallerBundle/StoreClient.php(277): Shopware\Bundle\PluginInstallerBundle\Service\UniqueIdGenerator\UniqueIdGenerator-
>getUniqueId() #4 /srv/www/htdocs/shopware/engine/Shopware/Controllers/Backend/FirstRunWizardPluginManager.php(157): Shopware\Bundle\PluginInstallerBundle\StoreClient->doTrackEvent(‚First Run Wizar…‘) #5 /srv/www/htdocs/shopware/engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_FirstRunWizardPluginManager->getLocalizationsAction() #6 /srv/www/htdocs/shopware/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚getLocalization…‘) #7 /srv/www/htdocs/shopware/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #8 /srv/www/htdocs/shopware/engine/Shopware/Kernel.php(179): Enlight_Controller_Front->dispatch() #9 /srv/www/htdocs/shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #10 /srv/www/htdocs/
shopware/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #11 /srv/www/htdocs/shopware/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #12 /srv/www/htdocs/shopware/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #13 /srv/www/htdocs/shopware/shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #14 {main} Next exception ‚Doctrine\DBAL\DBALException‘ with message ‚An exception occurred while executing ‚INSERT INTO s_core_config_values (element_id, shop_id, value) VALUES ( (SELECT id FROM s_core_config_elements WHERE name LIKE ‚trackingUniqueId‘ LIMIT 1), 1, ? )‘ with params [„s:32:"
eBRKtGBij0FBI8X1fa3SnYvcf6r8ZvHD";“]: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‚966-1‘ for key ‚element_id_shop_id‘‘ …
Anfangen kann ich damit nicht viel. Es deutet auf eine Inkonsitenz in der Datenbank hin.
Grüße
Möglicherweise auf eine bereits benutzte Datenbank draufinstalliert ?
Mal mit ner komplett Neuen leeren probieren.
Ich hab’s mit einer neuen, leeren Datenbank versucht, der FirstRunWizard wird dennoch immer wieder aufgerufen. Naja, dann eben nicht.
Grüße
vielleicht hilft ja das:
https://forum.shopware.com/discussion/comment/185866/#Comment_185866
oder die forensuche
