Sorry kann uns einer sagen was das genau heißt ??? 2014-02-08 12:47:34] core.ERROR: exception ‘Enlight_Exception’ with message ‘Could not construct form class’ in /var/www/vhosts/haleico.de/httpdocs/engine/Shopware/Controllers/Frontend/Forms.php:80 Stack trace: #0 /var/www/vhosts/haleico.de/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Frontend_Forms->indexAction() #1 /var/www/vhosts/haleico.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘indexAction’) #2 /var/www/vhosts/haleico.de/httpdocs/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #3 /var/www/vhosts/haleico.de/httpdocs/engine/Shopware/Kernel.php(137): Enlight_Controller_Front->dispatch() #4 /var/www/vhosts/haleico.de/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #5 /var/www/vhosts/haleico.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #6 /var/www/vhosts/haleico.de/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #7 /var/www/vhosts/haleico.de/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #8 /var/www/vhosts/haleico.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #9 /var/www/vhosts/haleico.de/httpdocs/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /var/www/vhosts/haleico.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #11 /var/www/vhosts/haleico.de/httpdocs/shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #12 {main}
[quote=“Ulli”]Sorry kann uns einer sagen was das genau heißt ??? 2014-02-08 12:47:34] core.ERROR: exception ‘Enlight_Exception’ with message ‘Could not construct form class’ in /var/www/vhosts/haleico.de/httpdocs/engine/Shopware/Controllers/Frontend/Forms.php:80 Stack trace: [/quote] Es scheint so, dass Du einen Link hast der auf ein nicht mehr existierendes Formular verweist. Z.B. mit https://www.haleico.de/forms/index/id/1337 bekomme ich die gleiche Fehlermeldung. Gruß
Danke
hm kann man rausfinden welches formular ???
[quote=“Ulli”]Danke
hm kann man rausfinden welches formular ???[/quote] Du könntest den Form Controller erweitern das dieser die übergebene ID in der Fehlermeldung mit ausgibt. Gruß
hallo
ich bin anwender wie geht das mit dem erweitern ???
