Fehler (Formular?) nach Update
Hallo Kollegen, nach dem Update auf 4.3.2 erhalte ich in sporadischen Abständen folgende Fehlermeldung via eMail: ERROR Message: exception 'Enlight\_Exception' with message 'Could not construct form class' in /www/htdocs/w005d2e9/www.kaffee-team.net/engine/Shopware/Controllers/Frontend/Forms.php:80 Stack trace: #0 /www/htdocs/w005d2e9/www.kaffee-team.net/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Frontend\_Forms-\>indexAction() #1 /www/htdocs/w005d2e9/www.kaffee-team.net/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('indexAction') #2 /www/htdocs/w005d2e9/www.kaffee-team.net/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #3 /www/htdocs/w005d2e9/www.kaffee-team.net/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #4 /www/htdocs/w005d2e9/www.kaffee-team.net/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #5 /www/htdocs/w005d2e9/www.kaffee-team.net/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #6 /www/htdocs/w005d2e9/www.kaffee-team.net/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #7 /www/htdocs/w005d2e9/www.kaffee-team.net/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #8 /www/htdocs/w005d2e9/www.kaffee-team.net/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #9 /www/htdocs/w005d2e9/www.kaffee-team.net/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /www/htdocs/w005d2e9/www.kaffee-team.net/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #11 /www/htdocs/w005d2e9/www.kaffee-team.net/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #12 {main} Time: 2015-01-10T11:36:41.744497+0100 Channel: core request: { "uri": "/forms", "method": "GET", "query": { "controller": "forms" }, "post": [] } session: { "sessionId": "c8cff469e4f4ed27ca3b0fa9ad3a06c9cc6d21eb", "Bot": true, "sOutputNet": false, "sPaymentErrorMethod": null, "sUserId": null, "sPaymentID": null, "sRegister": [], "sCountry": null, "sState": null, "sBasketQuantity": null, "sBasketAmount": null } shopId: 1 shopName: Deutsch Damit kann ich leider nichts anfangen - wird dies durch ein Formular (wenn ja, welches?) verursacht? Bestellungen funktionieren, sonst kann ich auch nichts fehlerhaftes feststellen. Weiß hier jemand zu helfen? Vielen Dank und ein entspanntes Wochenende, Eric.
Hallo Eric, die Meldung bedeutet, dass im Hauptshop ein Link zu einem Formular aufgerufen wird, welches es nicht (mehr) gibt. Du müsstest also deine Formulare bzw. Links mal prüfen. Kontakt, Anfrage zu Artikel, Support beantragen etc. Sebastian PS: es kann aber auch einfach sein, dass ein generell nicht verfügbares Formular versuc wird aufzurufen. Bewusst oder oder einen alte Link bei Google. Dann kannst du die Meldung venachlässigen, wenn die Formulare generell funktionieren, die du benötigst
