Hallo Kollegen,
wir haben seit dem Update auf 5.3 eine Problem mit den Produktexporten der diversen Preisvergleiche etc.
hier mal der Log -> weiß jemand da Bescheid?
## Ups! Ein Fehler ist aufgetreten!
### SQLSTATE[42S22]: Column not found: 1054 Unknown column 'us.countryID' in 'where clause' in engine/Library/Zend/Db/Statement/Pdo.php on line 224
### Stack trace:
"#0 engine/Library/Zend/Db/Statement.php(297): Zend\_Db\_Statement\_Pdo-\>\_execute(Array) #1 engine/Library/Zend/Db/Adapter/Abstract.php(470): Zend\_Db\_Statement-\>execute(Array) #2 engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(232): Zend\_Db\_Adapter\_Abstract-\>query('\n SE...', Array) #3 engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(96): Zend\_Db\_Adapter\_Pdo\_Abstract-\>query('\n SE...', Array) #4 engine/Library/Zend/Db/Adapter/Abstract.php(725): Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql-\>query('\n SE...', Array) #5 engine/Shopware/Core/sExport.php(1625): Zend\_Db\_Adapter\_Abstract-\>fetchAll('\n SE...') #6 engine/Shopware/Core/sExport.php(1714): sExport-\>sGetPremiumDispatchSurcharge(Array) #7 engine/Shopware/Core/sExport.php(1421): sExport-\>sGetArticlePremiumShippingcosts(Array, Array, Array, Array) #8 var/cache/production\_201708081547/templates/export\_3/6e/48/fe/6e48fe029e03c98245ab8146d2afd8382f0bb8a1.string.php(59): sExport-\>sGetArticleShippingcost(Array, Array, Array) #9 engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(180): content\_599b0200038666\_35277306(Object(Enlight\_Template\_Default)) #10 engine/Shopware/Core/sExport.php(1160): Smarty\_Internal\_TemplateBase-\>fetch('string:{foreach...', 3) #11 engine/Shopware/Controllers/Backend/Export.php(133): sExport-\>executeExport(Resource id #2262) #12 engine/Shopware/Controllers/Backend/Export.php(69): Shopware\_Controllers\_Backend\_Export-\>generateExport('php://output') #13 engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_Export-\>indexAction() #14 engine/Library/Enlight/Controller/Dispatcher/Default.php(525): Enlight\_Controller\_Action-\>dispatch('indexAction') #15 engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #16 engine/Shopware/Kernel.php(184): Enlight\_Controller\_Front-\>dispatch() #17 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #19 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #20 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #21 shopware.php(118): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #22 {main}"
