ich erhalte folgenden Fehler, sobald ich einen Artikel im Backend aufrufen möchte. Das Ganze ist vermutlich irgendwo zwischen den Updates zur 5.2.12 passiert.
Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen.
An exception occurred while executing 'SELECT s0_.id AS id_0, s0_.articleID AS articleID_1, s0_.article_detail_id AS article_detail_id_2, s0_.description AS description_3, s0_.img AS img_4, s0_.main AS main_5, s0_.position AS position_6, s0_.width AS width_7, s0_.height AS height_8, s0_.relations AS relations_9, s0_.extension AS extension_10, s0_.parent_id AS parent_id_11, s0_.media_id AS media_id_12, s1_.id AS id_13, s1_.image_id AS image_id_14, s2_.id AS id_15, s2_.mapping_id AS mapping_id_16, s2_.option_id AS option_id_17, s3_.id AS id_18, s3_.group_id AS group_id_19, s3_.name AS name_20, s3_.position AS position_21 FROM s_articles_img s0_ LEFT JOIN s_articles s4_ ON s0_.articleID = s4_.id LEFT JOIN s_article_img_mappings s1_ ON s0_.id = s1_.image_id LEFT JOIN s_article_img_mapping_rules s2_ ON s1_.id = s2_.mapping_id LEFT JOIN s_article_configurator_options s3_ ON s2_.option_id = s3_.id WHERE s4_.id = ? AND s0_.parent_id IS NULL ORDER BY s0_.position ASC' with params ["15"]: SQLSTATE[42S22]: Column not found: 1054 Unknown column 's2_.id' in 'field list' in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 119 Stack trace: #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(836): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), 'SELECT s0_.id A...', Array) #1 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection->executeQuery('SELECT s0_.id A...', Array, Array, NULL) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(321): Doctrine\ORM\Query\Exec\SingleSelectExecutor->execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(969): Doctrine\ORM\Query->_doExecute() #4 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(924): Doctrine\ORM\AbstractQuery->executeIgnoreQueryCache(NULL, 2) #5 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(739): Doctrine\ORM\AbstractQuery->execute(NULL, 2) #6 engine/Shopware/Controllers/Backend/Article.php(1794): Doctrine\ORM\AbstractQuery->getArrayResult() #7 engine/Shopware/Controllers/Backend/Article.php(1978): Shopware_Controllers_Backend_Article->getArticleImages('15') #8 engine/Shopware/Controllers/Backend/Article.php(1426): Shopware_Controllers_Backend_Article->getArticle('15') #9 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_Article->loadStoresAction() #10 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('loadStoresActio...') #11 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #12 engine/Shopware/Kernel.php(178): Enlight_Controller_Front->dispatch() #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Enlight_Controller_Request_RequestHttp), 1, true) #14 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #15 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #16 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #17 shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #18 {main}
Woran kann das liegen?
